Battery/wifi problems every time I take the battery out to change SIM or SD card
I have a UBports edition Pinephone.  When I run the factory test image it passes the auto test.  However anytime I take out the battery to change the SIM or micro SD card and boot up it says I have 0% battery and wifi will not work.  It only boots up when plugged in and shuts down if I unplug after it boots. Even thought the battery was showing fully charged before I changed the SIM or Micro SD card.  After a reboot it normally goes to say the battery is 100% but again only boots if plugged in and dies if unplugged and Wifi will not work.  After several boot cycles it will suddenly start working fine until I remove the battery and have to start this all over again.  Has anyone else had this problem? Does anyone know a solution?
thanks
I have not had this problem, I have had my battery out for sd card swapping a lot of times !
Since the problem does eventually go away,
perhaps the phone or battery contacts have something on them.?
Could try carefully cleaning the contacts ?
(08-23-2020, 01:52 PM)BlunderingBushcraft Wrote: I have a UBports edition Pinephone.  When I run the factory test image it passes the auto test.  However anytime I take out the battery to change the SIM or micro SD card and boot up it says I have 0% battery and wifi will not work.  It only boots up when plugged in and shuts down if I unplug after it boots. Even thought the battery was showing fully charged before I changed the SIM or Micro SD card.  After a reboot it normally goes to say the battery is 100% but again only boots if plugged in and dies if unplugged and Wifi will not work.  After several boot cycles it will suddenly start working fine until I remove the battery and have to start this all over again.  Has anyone else had this problem? Does anyone know a solution?
thanks
Are you having this problem while using the charger?
I only had this happen (battery seeming to lose all juice and wifi not working) when I tried to use without battery, while plugged into charger.
Try taking battery out n putting it back in *while disconnected* from charger.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
(08-23-2020, 05:18 PM)bcnaz Wrote: I have not had this problem, I have had my battery out for sd card swapping a lot of times !
The contacts look ok but it is worth a shot I will try this and see if it helps
thanks
thanks
I take the battery out with the phone turned off and disconnected from the charger.  Then after I put the battery back in I can only boot if it is charging
Just gave them a good clean with an alcohol wipe and put the battery back in and it booted right up without being on the charger.  I totally did not think that would work but there must have been just enough residue left from the tape when it came from the factory. This will make trying new distros so much less of a pain.
Thanks so Much
Sometimes the simple solutions work.
I had a friend that had an auto repair shop,
He would get a couple of cars per year towed to his shop that the customer would say it just quit running.
It would turn out to be simply "out of gas"
  Battery connector dead mdk 5 3,692 01-15-2026, 02:24 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,721 03-25-2025, 08:51 PM
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 2,094 10-14-2024, 03:34 PM
Last Post: luxgiammi
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 2,859 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,736 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 6,354 08-27-2023, 07:53 AM
Last Post: aular
  Battery life improvement freelectro 10 10,818 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 4,921 03-20-2023, 12:54 AM
Last Post: bcoyle
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 42,753 01-29-2023, 12:20 PM
Last Post: skandigraun
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 11,803 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
