Media server
My plan is to set up my Pine to use as a media server, mostly for video.  I've been digitizing my DVD collection onto a 2TB external hard drive, which I would plug into the USB port.
I do have a question though.  I bought 2 boards, both with the wi-fi/bluetooth chips.  If I have one board plugged into my TV out front, with the hard drive attached, could I use the 2nd board, connecting over the wi-fi, to access the data on the hard drive from another room?  Basically, wondering if I can have the 2nd board setup in my bedroom and still access the movies on the hard drive connected to the 1st board, without having to move the hard drive between boards.
I plan to run this on Android, but wondering if it will be the best OS for me for a media server?  Is there a different OS that would work better?  I don't really know what all the OS's are, so if someone else is doing a media server, I'd be interested to know how you are setting it up.  Thanks!
Does not matter for the os, you have options. My recommendation is either plex or kodi. Better to have a wifi router to connect to your network. There our other programs out there, just everyone has a preference.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Ok. And Plex or Kodi would be run on Android, yes?
I have wi-fi at home, was wondering if I could connect the devices over the existing wi-fi I have.
Thanks.
Yes, you can connect using your existing WiFi. Plex and kodi can run on android, but i dont know if plex can run on android via server mode. I hadn't checked in a bit.
  Mastodon instance \ Nextcloud Server fearg 1 7,881 03-31-2020, 08:18 PM
  Plex server arghne 59 195,664 07-06-2018, 10:36 AM
Last Post: Moshe.Vazan
  Turn your Pine64 into a music server with mpd JulianM 2 15,161 03-23-2017, 10:50 PM
  Plex server arghne 48 83,689 03-22-2017, 04:15 AM
Last Post: pineadmin
  Pine64 as NAS/Media Server VandaL.pr! 1 8,677 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 8,930 09-13-2016, 02:43 AM
Last Post: JAYJAYN
  Cannot install Plex Media Server under Arch Linux malevolent 2 8,846 09-11-2016, 12:20 PM
Last Post: ChrisLane
  Building Stratum One NTP Server lospinos 5 14,452 08-23-2016, 09:23 AM
Last Post: MarkHaysHarris777
  Starbound Server. Is the Pine64 capable? iamfallen 1 6,190 08-03-2016, 10:36 AM
Brick Minecraft Server chrislink14 16 42,832 05-06-2016, 08:03 AM
Last Post: jeremycobert
