Pinephone battery
I ve read somwhere that battery life for the Pinephone when always running is about two hours. That s too short for my purpose. I ve serached everywhere to find bigger Samsung J7 battereies. Unfortunately, I could not find any.  I have to find a solution with a external power bank. But the usb-c connector is not optimal for this. I miss an adapter from the Pinephone battery connector to usb power.
(07-29-2020, 03:34 AM)Peter Gamma Wrote: I ve read somwhere that battery life for the Pinephone when always running is about two hours. That s too short for my purpose. I ve serached everywhere to find bigger Samsung J7 battereies. Unfortunately, I could not find any.  I have to find a solution with a external power bank. But the usb-c connector is not optimal for this. I miss an adapter from the Pinephone battery connector to usb power.
You could look into the power connections on the Pogo Pins. I think they're intended to be used both for powering devices using the i2C, and for external power such as a back cover with battery, or wireless charging adapter. I think there's some question as to the accuracy of the documentation (3.3V pin actually 5V?), so you should check and probably measure before using it.
Thank you for your detailed answer, Wibble. But I think I will choose an usb-c hub with an additional connector to attach a power bank:
https://forum.pine64.org/showthread.php?...5#pid73465
The Pinephone battery would then only serve a second battery to protect from power loss loss.
  Pinephone visibly losing power while plugged in Hiraghm 9 8,919 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,628 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,572 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,799 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,593 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,617 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,153 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,790 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,195 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,471 10-21-2025, 12:12 PM
Last Post: Richy_T
