WIFI board information?
Looking for the information on the WIFI board.  Is it possible connection an external antenna?
(04-27-2016, 12:01 PM)queonda Wrote: Hello,
You can connect to external antenna.
Is there any information you can point me to?
Sent from my SAMSUNG-SM-G935A using Tapatalk
(04-28-2016, 01:34 PM)queonda Wrote: Is there any information you can point me to?
Just detach the wire antenna comes with Wifi/BT module and you will spot an U.FL (see attached picture), you can connect your external antenna to this connector. However, if your external antenna is SMA type, you need a conversion cable.
Thank you! I should get my board mid month.
  [split] Better WiFi/BT module? moriel5 3 10,553 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,764 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,179 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,234 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,829 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,824 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 6,172 07-22-2018, 07:15 AM
  +LTS/SOPINE Footprint for the recommended Wi-Fi+BT breakout board Madhuwesly 1 5,221 04-09-2018, 04:07 PM
  Unable to activate wifi on Linux smouton 10 24,812 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,097 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
