Phone Won't Detect Music Files From SD Card
I've been having issues with my Pinephone detecting my music files from my Micro SD Card. I ended up buying a 256GB Micro SD card just so I can take all of my music with me on the phone, but for some reason the Music app says 'no music files detected'.
did you mount your sdcard? basically none of the distros mount sd cards by default without some extra steps
(07-24-2020, 05:12 PM)hiimtye Wrote: did you mount your sdcard? basically none of the distros mount sd cards by default without some extra steps
How do I mount the SD card?
that's a question with more than one answer. I mount SD Cards by loading udiskie. others add their SD card to /etc/fstab. before, I mounted an SD card by using a bash script but I got annoyed that I had to change it every time I reformatted or changed the SD card
(07-25-2020, 12:51 AM)hiimtye Wrote: that's a question with more than one answer. I mount SD Cards by loading udiskie. others add their SD card to /etc/fstab. before, I mounted an SD card by using a bash script but I got annoyed that I had to change it every time I reformatted or changed the SD card
I appreciate the response, but I have no idea what you just said. I'm not exactly an advanced Linux user, so any step by step information would be helpful. =)
Which distro are you using? Some methods will work with one but not another.
I'm using the UBports edition Pinephone.
(07-27-2020, 10:02 PM)Joelandsonja Wrote: I'm using the UBports edition Pinephone.
That's the hardware version. The distro would be UBPorts (which it probably arrived with), Mobian, PmOS etc.
(07-22-2020, 01:52 PM)Joelandsonja Wrote: I've been having issues with my Pinephone detecting my music files from my Micro SD Card. I ended up buying a 256GB Micro SD card just so I can take all of my music with me on the phone, but for some reason the Music app says 'no music files detected'.
You're not the only one. The music application also doesn't detect my music files (even after I mount he SD card). I even tried making a sym link from the SD card music files to my music folder in my home directory. No dice.
I am able to get the player to import songs by navigating to them in the file manager and opening them with music player, though. Once imported, they stay there. I just don't want to do this for each song in my library.
What the others are trying to dell you is that your SD card doesn't automatically mount in Ubuntu Touch. You have to manually mount it using various methods. For instance, I created a folder named sd in my home directory and then mounted the card there:
mkdir ~/sd
mount /dev/mmcblk0 ~/sd
You can then navigate to the files on the card from the terminal or in the file manager.
mkdir ~/sd
Didn't work for me, but I might have made a typo somewhere along the line.
I'm hoping UBports will do a significant update soon, because this thing has just been sitting in my drawer for a month.
  Default password for KDE plasma pine phone Toni 0 8,103 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 4,390 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 2,936 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 3,894 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 6,105 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 8,389 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 12,078 03-11-2024, 10:42 PM
Last Post: Emelia525
  install iso from sd card to emmc aular 2 3,636 03-11-2024, 10:24 PM
  How To Share The External MicroSD Folders and Files On A Network? pinephoneuser22 5 6,271 02-10-2024, 08:47 AM
Last Post: jakfish
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,322 01-09-2024, 07:02 PM
Last Post: britelite
