Mobian
Hey all
I installed Mobian on my PinePhone and loved it
2 errors
when my phone is in idle mode my screen keeps popping up the date and time, can I switch it of to save battery?
The big issue I have is that when I play music on is, my volume buttons dont work, I can switch my music lower or higher, does anyone has a fix on it please
Regards
The volume buttons do not yet work in phosh, but there is a MR for phosh/phoc which should be merged pretty soon,
so that should probably be working some time next week ;)
There are some events which trigger a wakeup of the phone (periodically?). Personally I do not quite know what their origin is.
(07-23-2020, 12:56 PM)devrtz Wrote: The volume buttons do not yet work in phosh, but there is a MR for phosh/phoc which should be merged pretty soon,
so that should probably be working some time next week Wink
Thanks very much
(07-23-2020, 12:13 PM)jesica Wrote: ...
Yeah a known issue (and complete PITA as was previously sorted on 5.6 kernel) so hopeful a fix will be with us soon. One thing I find is this seems to be an artefact of something I do and on a clean rebooted system it is more liklely to settle and engage CRUST!
The workaround: Just tap the status bar at top of screen and use the slider. Again (as per devrtz) hopefully wont be too long until phosh gets there.
(07-23-2020, 12:13 PM)jesica Wrote: The big issue I have is that when I play music on is, my volume buttons dont work, I can switch my music lower or higher, does anyone has a fix on it please
This works as of yesterday evening.
Be careful with the update though:
https://forum.pine64.org/showthread.php?tid=10965
  Mobian MMS/SMS text problem bcnaz 16 38,685 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,649 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 67,100 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 72,682 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,312 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 341,947 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,993 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,129 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,851 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,574 04-29-2025, 02:10 PM
Last Post: mdk
