Manjaro sway profile for pinebook
I've just replaced my current OS on my regular 1080p pinebook with this https://forum.manjaro.org/t/sway-profile/138700/53
It is pretty lightweight so it fits perfect on the pinebook.
Kudos to @appelgriebsch for making this available for the pinebook (and the pinebook pro as well!)
(07-21-2020, 08:13 AM)e-minguez Wrote: I've just replaced my current OS on my regular 1080p pinebook with this https://forum.manjaro.org/t/sway-profile/138700/53
Excuse me, I'm new to manjaro. Could you give me a direction how to install the version you mention on pinebook?
Is is similar to the install process I've learned until now? Download iso, unpack & copy to SD card using "dd" command, boot.
Thanks.
Thanks.
Exactly. Download the img from https://osdn.net/projects/manjaro-arm-sw...rc4.img.xz and use dd or balenaetcher to 'flash it' to your SD card.
Thank you, I also found a helpful blog (https://www.appelgriebsch.org/004-manjaroarm/) with the story about creating the Manjaro Sway profile flavour for pinebook (pro).
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 5 15,172 10-25-2026, 04:11 AM
  DietPi OS for Pinebook MichaIng 5 18,038 07-28-2026, 08:02 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 106,569 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 6,245 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,735 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 17,514 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,745 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 11,100 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,849 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,774 01-20-2021, 11:18 AM
