Latest Installer Image hangs after updates
I used the latest 2020-Jul-16 12:26 image and was able to burn and SD card then go through the installation.  Once the installation completed and rebooted I went to the Software application and chose updates.  I got an initial error message about a Gnome component which I closed out then it showed all the updates.  I applied all the updates and rebooted.  Now it just hangs with a white/green/purple LED cycling.  I have tried this twice on two different SD cards with the same result.
Is this expected or have others noticed the same behavior?
(07-19-2020, 08:39 PM)u20200719 Wrote: I used the latest 2020-Jul-16 12:26 image and was able to burn and SD card then go through the installation.  Once the installation completed and rebooted I went to the Software application and chose updates.  I got an initial error message about a Gnome component which I closed out then it showed all the updates.  I applied all the updates and rebooted.  Now it just hangs with a white/green/purple LED cycling.  I have tried this twice on two different SD cards with the same result.
Here's a video showing the install, update, and boot failure after the update.
http://www.filedropper.com/postmarketosinstaller
Downloading and copying image to SD
wget https://images.postmarketos.org/pinephon...ler.img.xz
xz -d pine64-pinephone-20200716-phosh-v20.05-installer.img.xz
md5sum pine64-pinephone-20200716-phosh-v20.05-installer.img
0a09f1c62457076241eb5c9dd6dae631  pine64-pinephone-20200716-phosh-v20.05-installer.img
sudo dd if=pine64-pinephone-20200716-phosh-v20.05-installer.img of=/dev/sdb bs=4M
895+1 records in
895+1 records out
3757047808 bytes (3.8 GB, 3.5 GiB) copied, 411.442 s, 9.1 MB/s
Problem exists also here.
After the update no more boot. No screen output, display stays black here
New image available from 22-7-2020
(07-22-2020, 09:09 AM)firefox-58 Wrote: New image available from 22-7-2020
That seems to resolve it since there are no updates after loading with this installer.  The other installer worked, then failed to load after applying updates.  I'm not sure what the behavior will be if updates arrive with this version.
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 4,092 11-22-2023, 10:16 AM
Last Post: zetabeta
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,837 10-03-2023, 06:32 PM
  Issues after installing latest PostMarket OS with POSH xen314 4 8,046 08-20-2023, 11:18 PM
Last Post: xen314
  how to install updates? someGermanGuy 2 5,065 04-26-2022, 12:48 PM
Last Post: someGermanGuy
  Latest suggestion to fix modem instability? feklee 10 18,216 01-31-2022, 01:16 PM
Last Post: feklee
  Latest build no firefox, text editor? cosmicschock 2 4,988 10-03-2021, 12:19 PM
Last Post: cosmicschock
  Where is the original PM OS image for Pinephone? mw4jet 1 5,012 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 11,261 02-28-2021, 02:20 PM
Last Post: MtnSk8
  Is a Software update the same as instaling an updated image Word5 1 5,040 09-19-2020, 10:23 PM
Last Post: jmorris
  Incorrect Passphrase - FIx | How To Reinstall Image. NobodyNew1 0 3,525 09-02-2020, 09:30 PM
Last Post: NobodyNew1
