Sailfish install problem.
(02-24-2020, 10:51 AM)harvey186 Wrote: the flash-it finish successful, but nothing written on sd card
It's work for me.
I think instead  of :
Device node (/dev/sdx): mmcblk0
it should be:
Device node (/dev/sdx): /dev/mmcblk0
thx, it's working
For those, who has this problem but do not use mmc* as the SD card name, but SDB, please change your flash-it script:
https://github.com/sailfish-on-dontbeevi...e152da1dcb
Totally worked for me, now I have a lightning fast Sailfish OS. Networking does not seems to work yet, but OS itself is working. Smile
Thanks to Adam Pigg for the tip.
new version of the script 0.2 works fine with internal sd-card readers (/dev/mmcblk0)
Is there any reason why a script is required and an actual easy to flash img isn't just hosted somewhere? Those of us on mac or windows machines are basically out of luck.
(06-29-2020, 06:33 AM)patrickjquinn Wrote: Is there any reason why a script is required and an actual easy to flash img isn't just hosted somewhere? Those of us on mac or windows machines are basically out of luck.
You can burn another pinephone image on sdcard, and run the script firectly from there. This will install SFOS on eMMC.
  When mobile data works calls don't with Sailfish OS albafrati 0 2,930 06-25-2024, 09:28 AM
Last Post: albafrati
  Sailfish on PinePhone PiSe 4 4,845 06-17-2024, 05:46 AM
Last Post: PiSe
  Pinephone keyboard with Sailfish fn-keys idc 1 3,468 01-28-2023, 11:48 AM
Last Post: idc
  Using Windows 10 to install SailfishOS Kimberley van Buyten 1 3,619 12-05-2022, 10:36 AM
Last Post: Andidoko
  PinePhone versus Sailfish (Sony/Jolla) richieeee 10 18,678 07-10-2021, 04:18 AM
Last Post: acrux
  Lock screen problem? undo 5 10,369 03-03-2020, 05:00 AM
Last Post: explit
  Sailfish web browser linux6730 3 8,840 02-25-2020, 05:42 AM
Last Post: DrYak
  Sailfish still supported? Mangled 4 9,862 02-08-2020, 08:22 PM
Last Post: Mangled
