Keep Wifi Connection alive
So I've posted about this issue here before; tried some things, still having same problems.
The short of it is that the wifi sucks on this device (or in Debian). I received the Debian 9.12 release early this year, having pre-ordered I believe around October of last year. Did all the related update stuff, etc. to get it running.
The only way I can keep a consistent connection on the device is that I have created a bash script that starts automatically at login, running an ongoing ping to yahoo.com. It runs in the background and when it is running, wireless works good. If that ping dies for some reason, soon the wifi drops and will not connect again. It was the only solution I could come up with to just get this thing to stay on the network.
I specifically ping the domain name (yahoo.com) to verify DNS resolution, which is odd. If I run a regular IP ping, it will work, but not as quickly as when I resolve DNS first; even pinging on my own network. However, opening a browser and going to yahoo.com or another website doesn't seem to pull off the same "kick-start" that the ping is doing; it won't resolve and display the page.
So, I'm open to any suggestions about a better OS to run, or something to make this thing run as it should. Love the hardware, I just think that the release with Debian 9.12 has been ....whatever. Sad
try going into settings > power > toggle the Wi-Fi can be turned off to save power , if thats available
this is using mobian on pinephone / which is debian based.
(07-08-2020, 09:43 AM)vve1505 Wrote: The short of it is that the wifi sucks on this device (or in Debian)
Yes, WiFi sucks in Debian, at least in the one that used to come stock with the PBP. I am currently using Manjaro XFCE off an SD card, and WiFi is rock solid with it, has a better range, and is possibly also faster.
Have you tried the tlp solution? Install tlp and go to the config file. Uncomment (delete the hash) for wifi power savings and make power savings be off on ac and on battery. I hope this helps! About suggestion world be too re-seat the wifi antennae inside the unit, but if it's working in other distros, I doubt that's the issue. Hope this helps! Keep on hackin'!
(07-10-2020, 08:15 AM)mamboman777 Wrote: Have you tried the tlp solution? Install tlp and go to the config file. Uncomment (delete the hash) for wifi power savings and make power savings be off on ac and on battery.  I hope this helps!  About suggestion world be too re-seat the wifi antennae inside the unit, but if it's working in other distros, I doubt that's the issue. Hope this helps! Keep on hackin'!
Thank you for this suggestion!
I'm still stuck on Debian at present
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 6,328 03-31-2025, 07:14 AM
Last Post: Anarethos
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 2,984 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 2,180 03-11-2023, 03:21 PM
Last Post: filip
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 6,489 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 3,151 07-22-2022, 01:35 PM
Last Post: poVoq
  wifi hotspot ip address symbol.accounting@gmail.com 1 4,198 11-07-2021, 12:58 AM
Last Post: dukla2000
  Wifi Troubles IDEFK 17 28,010 05-24-2021, 05:03 AM
Last Post: walterbe
  Pinebook pro poor performance on 5Ghz WiFi Iolaum 10 22,377 05-23-2021, 04:35 AM
Last Post: Ralim
  Network connection question??? davehetfield 1 6,325 03-11-2021, 07:31 AM
Last Post: tkudog
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 6,944 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
