Pinephone charging issues after fully depleting battery.
I left my pinephone out for a day on standby and now I am unable to charge the battery through the device. I doubt that running the battery completely dead one time would kill it. Has anyone seen this before? Is there someway to make the device begin charging?
My OS still boots when plugged in.
Yes, I have removed the plastic tab from the battery.
UPDATE: Forgot to tell you, ubports suggested it was fully charged. PureOS appears to be charging only time will tell.
It shouldn't be a problem, but may depend on OS and charger. It has worked for me in PmOS and Mobian with the charger from a Nexus 5X.
(07-01-2020, 12:37 PM)plainenough Wrote: I left my pinephone out for a day on standby and now I am unable to charge the battery through the device. I doubt that running the battery completely dead one time would kill it. Has anyone seen this before? Is there someway to make the device begin charging?
Some updates back, when my phone got run down to 0% charge, it appeared to not be charging,
  .......   then it was charging at .02 watts
for a long time..
 But when it got to a few percent charge it finally started charging properly again.
  I am not certain if that was hardware or software
IT has went to 0% one time since,  but it seems to charge OK now.
The nature of working with Beta  operating systems 'I guess'  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Quote:Some updates back, when my phone got run down to 0% charge, it appeared to not be charging,
for a long time..
That sounds normal. If the battery gets near completely flat, it will take a while of charging at a very low current to get it to a level it's safe to kick on the full charging current. There's a small hardware defect where the phone slowly drains battery when turned off, so if you're gonna store it, take out the battery first.
Sorry for the late reply, I booted from pureos and it charged normally.
*  I ordered the external battery charger today,
  So I can charge the battery regardless of any other factors,  hardware, software issues.
The $11.99 shipping is not cheap,    so I bought a  'bunch of stuff'  and the shipping charge did not go up.
                                   Big Grin
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(07-01-2020, 12:46 PM)wibble Wrote: It shouldn't be a problem, but may depend on OS and charger. It has worked for me in PmOS and Mobian with the charger from a Nexus 5X.
(07-15-2020, 05:54 PM)bcnaz Wrote: *  I ordered the external battery charger today,
                                   Big Grin
I would love to get an external charger and an extra battery. Do you have a link, I have looked with little success.
I just noticed the section for pinephone spare parts.
I Guess I forgot to mention I was shopping at the Pine64 store, sorry.
The replacement batteries were listed as 'out of stock' or I would have bought one of those also.
Some of the items, such as the replacement back cover are a limit of one per customer.
I do not remember if they have a limit on batteries, just that they did not have them.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I've noticed the battery drain when off issue on Braveheart. If it has been identified as hardware related have any distros implemented a software fix or is it an issue we're stuck with?
(07-18-2020, 07:37 AM)brb78 Wrote: I've noticed the battery drain when off issue on Braveheart. If it has been identified as hardware related have any distros implemented a software fix or is it an issue we're stuck with?
You can curtail the drain by killing the modem and replacing (ejecting, then inserting) the battery. The battery will experience nominal drain unless you eject it from the phone.
  Pinephone + Keyboard for sale, little use ruemoo 16 11,653 07-07-2026, 04:47 PM
Last Post: PinePhoneProUser
  Pinephone - broken power button rorus 14 23,887 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 1,583 01-20-2026, 01:43 PM
Last Post: Anna
  Battery connector dead mdk 5 4,175 01-15-2026, 02:24 PM
Last Post: mikeb
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 19,967 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,869 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 3,077 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,338 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,778 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,166 06-21-2025, 05:19 PM
Last Post: mikeb
