Simple Enclosure from CD covers
I have put together this simple enclosure from CD covers
(04-25-2016, 11:22 PM)gsinjari Wrote: I have put together this simple enclosure from CD covers
Pretty nice and a good idea! Can you cut the clear other shell of the case well enough? It would look even smoother I guess.
Yes you can cut the clear side using a sharp cutter, but it is little difficult to make holes in it. I haven't tried that as I used all I had for a hologram Smile
what did u use for spacers?
Did you have to make the holes for the standoffs/spacers bigger? I have some brass ones from PC building and they seem too big for the holes in the board but I'm sure they are the M3 size everyone says you should use.
(05-04-2016, 11:25 AM)Kiwiboyus Wrote: Did you have to make the holes for the standoffs/spacers bigger? I have some brass ones from PC building and they seem too big for the holes in the board but I'm sure they are the M3 size everyone says you should use.
I would never tamper with the board and, though I'm no expert, my advice is not to do so. I had that issue, I wanted to use some stuff I had around for spacers and they were too big, so I just forgot about it and thought of something else.
You can crack the plastic, or any of the circuit or resin layers. In theory there should be no problem, but if I can think 2 or3 things that could go wrong, then there should be more.
Pine 64 2GB - Remix OS  - HP wireless keyboard = Working - PS3 controller with USB = Working
Pretty nifty !
What are the spacers?
Sent from my iPhone using Tapatalk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 31,963 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 50,499 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,229 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,568 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,669 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 20,818 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 38,374 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 30,925 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,124 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 10,243 10-13-2016, 08:47 AM
Last Post: Bluphire
