Can I use RaspBerry Pi Modules with the Pine?
I have a Pine64+ with 2GB RAM and am a newbie. I did buy th WiFi Module but now I regret not doing so with the Camera.
Do other RaspBerry Pi Modules available in on Amazon work with Pine?
And if I may ask further, can other components like Proximity and Ambient Sensors also work?
(04-25-2016, 06:30 AM)shivamvahia Wrote: I have a Pine64+ with 2GB RAM and am a newbie. I did buy th WiFi Module but now I regret not doing so with the Camera.
A Pi camera will definitely NOT work on the Pine, the connectors while physically slightly similar have vastly different pin spacing and I would imagine pinout. At this time I am not sure the Pine folks are even shipping a working camera yet as they evidently found noise issues with theirs.
As for modules, where to begin..
The pine64 has GPIO pins so do the Pi. The headers are supposed to be similar and compatible? When you compare the pine ( http://files.pine64.org/doc/Pine%20A64%2...160119.pdf ) to the Pi ( http://www.raspberry-pi-geek.com/var/rpi...ghtbox.png ) they appear to be the same. So connecting them may work. The problem you are going to find is getting it to work. While I know someone has already ported one of the python libraries from the Pi ( http://forum.pine64.org/showthread.php?t...ght=python ) . Will things work? No one can say until they have been tested. Is there risk in such testing, possibly. So keep that in mind.
Individual sensors that connect to individual pins will likely be the most compatible using the appropriately ported software.
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,311 10-06-2022, 08:46 PM
Last Post: ihab
  pine store paulhide 1 5,488 09-17-2020, 04:13 AM
Last Post: bcnaz
  1 of 7 SoPINE compute modules not receiving DHCP lease ClusterMaker 2 5,937 09-08-2020, 03:03 AM
Last Post: Dippywood
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 9,077 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 12,544 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 10,761 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 13,637 09-19-2018, 10:30 AM
Last Post: mjgoode
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 8,084 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 10,312 02-12-2017, 05:12 PM
Last Post: Arlanps
  Would the SOPINE modules work if they were put into a standard SODIMM RAM slot? Wiooooo 4 10,684 02-05-2017, 02:57 PM
Last Post: MarkHaysHarris777
