Problem with ESP32 connected to USB2. USB3 - seems OK.
Hi all.
I am using platform.io framework in vs code on PBP and having problem with communication to ESP32 dev kit from USB2 (right) port.
For example when I am running monitoring of ESP32 serial port I get errors:
Value 1:249.71 Value 2:94.25 Value 1:153.50 Value 2:251Exception in thread rx: --- exit --- Traceback (most recent call last):   File "/home/erik/.platformio/penv/lib/python3.8/site-packages/serial/serialposix.py", line 500, in read     raise SerialException( serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?) During handling of the above exception, another exception occurred: Traceback (most recent call last):   File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner     self.run()   File "/usr/lib/python3.8/threading.py", line 870, in run     self._target(*self._args, **self._kwargs)   File "/home/erik/.platformio/penv/lib/python3.8/site-packages/serial/tools/miniterm.py", line 445, in reader     data = self.serial.read(self.serial.in_waiting or 1)   File "/home/erik/.platformio/penv/lib/python3.8/site-packages/serial/serialposix.py", line 509, in read     raise SerialException('read failed: {}'.format(e)) serial.serialutil.SerialException: read failed: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
After some good reading it failed.
If I use USB3 (left) port. Everyhing is fine.
  Yet another new Pinebook keyboard problem MikoBob 3 5,870 09-11-2024, 07:05 AM
Last Post: MikoBob
  Problem with USB 3.0 Type A hobbitus 4 5,959 07-15-2023, 11:14 AM
Last Post: dachalife
  Curious about problem with PBP Wifi kendew 3 8,537 01-14-2021, 11:16 AM
Last Post: clover
  Auto-wake behavior when external power is connected diodelass 7 16,906 12-05-2020, 01:19 AM
Last Post: dsimic
  NVME problem chaoskampf 2 9,819 07-01-2020, 09:10 AM
Last Post: chaoskampf
  USB3 won't power 2,5" external HDD Tiedemate 8 19,003 01-08-2020, 05:45 PM
Last Post: Tiedemate
  keyboard problem romansvec 12 22,616 11-11-2019, 02:45 PM
Last Post: CryptoRick
