Noisy power light.....
This morning, for the first time I can remember, the power light began flickering with noise. The noise sounds like a fluttering relay with some light beeping. I'm currently using Balena Etcher to flash an SD card. Disconnecting the AC power supply had no effect.
When Etcher finished, the noise stopped the flickering continues.....
Not aware of anything being mentiond about this particular event. Does anyone have an idea?
Many Thanks, Rick :-)
It's not noisy, it's showing disk activity.
Unless you are saying that it is continuing to flash on/off?
Arwen Evenstar
Princess of Rivendale
(06-17-2020, 08:20 AM)Arwen Wrote: It's not noisy, it's showing disk activity.
Thanks for helping!
It was odd it occurred only when using Etcher to write to an SD card.....
And being the eMMC is solid state, it never made any sounds like that before....
No big concerns about it. Thought it might be worth mentioning.
Will post anything else that happens....
  Pinebook64 Pro doesn't power on andrea_from_italy 9 9,273 03-20-2025, 10:07 AM
  Lockable-until-power-cycle persistent storage Melab 0 2,758 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 3,041 07-20-2023, 11:06 PM
Last Post: papable
  Blinking Tiny Blue Indicator Light? ArchiMark 3 4,933 06-30-2023, 03:15 PM
Last Post: Samurai_Crow
  When does Pinebook Pro power LED go on? Bram 0 2,702 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 5,517 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 7,086 09-09-2022, 08:13 PM
  Replacement Power Cord recommendation? nathanielwheeler 3 6,849 01-23-2021, 06:43 PM
  [SOLVED] Red light flashes next to barrel-port Carl 31 78,206 01-18-2021, 09:34 AM
Last Post: dsimic
  power light blinking during charge when pbpro is off Idaho 0 4,344 01-04-2021, 10:53 AM
Last Post: Idaho
