postmarketos-mkinitfs upgrade failing
Today, a new version of postmarketos-mkinitfs tried to install when I ran apk upgrade.
However, the trigger script errored out, so it couldn't install the upgrade. I ran apk fix to try and redo the installation, but it failed again.
pinephone:~$ sudo apk fix (1/1) Reinstalling postmarketos-mkinitfs (0.12.1-r1) Executing busybox-1.31.1-r20.trigger Executing postmarketos-mkinitfs-0.12.1-r1.trigger ==> initramfs: creating /boot/initramfs-postmarketos-allwinner Scanning kernel module dependencies... NOTE: ** modprobe warnings below can be ignored ** if your device does not run the mainline kernel yet (most devices!) or if the related kernel options are enabled with 'y' instead of 'm' (module). - deviceinfo: sun6i_mipi_dsi sun4i_drm pwm_sun4i sun8i_mixer - 00-default.modules: dm_crypt ext4 usb_f_rndis ==> kernel: device-tree blob operations ==> kernel: copying dtb allwinner/sun50i-a64-pinephone-1.1 to boot partition ==> initramfs: creating uInitrd Image Name:   uInitrd Created:      Sun Jun 14 23:09:53 2020 Image Type:   AArch64 Linux RAMDisk Image (uncompressed) Data Size:    1427565 Bytes = 1394.11 KiB = 1.36 MiB Load Address: 00000000 Entry Point:  00000000 ==> kernel: creating uImage mkimage: Can't open /boot/vmlinuz-postmarketos-allwinner: No such file or directory ERROR: postmarketos-mkinitfs-0.12.1-r1.trigger: script exited with error 1 Executing postmarketos-base-3-r34.trigger Configuring a getty on port ttyS0 with baud rate 115200 OK: 1420 MiB in 583 packages pinephone:~$ ls /boot/ initramfs-postmarketos-allwinner  uImage-postmarketos-allwinner sun50i-a64-pinephone-1.1.dtb      uInitrd-postmarketos-allwinner
Running apk fix, it gets picked up as improperly installed again.
The file it is looking for does not exist, there is an ls output at the bottom.
Any ideas? It'd be much appreciated.
Thanks in advance!
Please make sure the kernel package is installed. "/boot/vmlinuz-postmarketos-allwinner" is provided by linux-postmarketos-allwinner so "apk add linux-postmarketos-allwinner" should do the trick. I wonder why it got uninstalled for you, that will break booting.
(06-16-2020, 12:25 AM)PureTryOut Wrote: Please make sure the kernel package is installed. "/boot/vmlinuz-postmarketos-allwinner" is provided by linux-postmarketos-allwinner so "apk add linux-postmarketos-allwinner" should do the trick. I wonder why it got uninstalled for you, that will break booting.
Looks like this was indeed the package with issues, however it was already installed. Solution was:
sudo apk fix linux-postmarketos-allwinner
...to reinstall it. Then I ran:
sudo apk fix
...and the original trigger executed properly.
Thanks for the help.
Just a quick aside - if these are kernel updates, does that mean there's no difference (from a hardware support perspective) between flashing a new image and simply running "apk upgrade" on an existing install?
Yes there is no different between "apk upgrade -a" and a new install. We never told anyone to reflash when a new image goes live so I wonder where people got the idea from that it would be required. It's just a regular Linux distribution after all.
Information PostmarketOS renamed to Nura ptw 0 71 11-19-2026, 08:01 AM
Last Post: ptw
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,928 11-18-2024, 02:23 AM
Last Post: linmob
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 3,450 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  installed postmarketos v23.06 no audio samlo 1 4,595 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 4,089 07-01-2023, 08:16 AM
Last Post: AndyM
  VPN for PostmarketOS publiclewdness 1 5,064 03-11-2023, 04:35 PM
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 5,093 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,376 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 6,569 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Pinephone Keyboard Utilities on postmarketOS elof 2 7,396 06-20-2022, 01:33 PM
Last Post: elof
