Ubuntu Touch with OTA updates
#51
version 49 still has high res/ small icons, it is the dev version ....... so stuff happens
#52
(06-15-2020, 07:57 AM)Djhg2000 Wrote: @LMalilil @afigegoznaet
You'll need to flash a stable image and start from there, as far as I'm aware there's no downgrade process.
You can get the latest stable build here and flash it with the latest version of Jumpdrive from here.
I was able to downgrade by selecting the "Stable" branch, and installing the stable "update".
#53
49 seems pretty good aside from being able to hear on calls (makes and receives). A few blank kryboard keys and on the dial pad. Egerything else including crust seems to function properly. Tiny bit of keyboard delay as well
#54
I'm on 49 as well and Crust is working very well! The resolution is still way to small and I need my old man reading glasses..hahaha.
The one odd thing I did just find is that my sound no longer works for any media playback. I could not anything playing through either bluetooth or wired headphones since I received the phone but now no media is playing through the phones speakers since I downloaded 49. Weird.
Can anyone else see if they are experiencing the same issue?
#55
Still no voicecall sound on BH.
Media sound works, though
#56
50 is really nice. Resolution fixed. Smooth. Fast. Wakes out of deep sleep. only thing I'm noticing problem wise is a few buttons on the dial pad and keyboard not rendering and no sound on voice calls
*edit*
Noticing sms and data cuts out during deep sleep sometimes. Not consistently but when it does you have to do a warm reset
#57
Hi, i updated to #51 (dev) 10 minutes ago. Browsing on the internet is sooo smooth. Where can i find the changelog of every update on Jenkins/Gitlab?
Thank you!
#58
(06-17-2020, 02:15 AM)m.alizade7 Wrote: Hi, i updated to #51 (dev) 10 minutes ago. Browsing on the internet is sooo smooth. Where can i find the changelog of every update on Jenkins/Gitlab?
Thank you!
If they don't supply a change log for a build then you will have to look up all the different repositories that make up the OS and look at the new Commits, which is quite a task:
https://github.com/ubports
Alternatively you can compare build logs in Jenkins, but it'll be work either way.
I wish the change log would be more informative as well. Smile
#59
Updated to #51 (dev). For me this is a step back from #50.
Working:
- Incoming calls (no audio)
- Text messages
- Scaling
New Issues:
- Outgoing calls not working
- Network signal very unstable (I had this problem before but with another sim card and carrier)
Existing Issues:
- Calling with audio not working
- Missing Icons (Dialer, Virtual Keyboard)
#60
Smile
Thank you!
Thanks for the info! Smile
  Ubuntu Touch on Pine64 Rondarius 11 17,208 10-11-2023, 12:36 PM
Last Post: Rondarius
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 20,221 06-26-2023, 07:50 AM
Last Post: gregb49
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 9,217 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  UB Touch build with debos layton-dev 0 7,493 04-23-2021, 08:12 AM
Last Post: layton-dev
  Whats the latest with UB touch? Cree 9 19,096 03-11-2021, 10:59 AM
Last Post: andybleaden@gmail.com
  UT move to Ubuntu 20.04 Concrete_panda 2 8,814 11-24-2020, 12:43 PM
Last Post: DrewTechs
  Horrible energy consume on Pinephone/UB-Touch firefox-58 9 19,395 10-15-2020, 12:28 PM
Last Post: plainenough
Star Updates stuck on stable channel. Cree 6 13,266 10-04-2020, 11:26 AM
Last Post: Giiba
  Pinephone 3G Bluetooth Working Pretty Well With Latest Mobian Updates rmcg 0 4,353 09-27-2020, 10:22 PM
Last Post: rmcg
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 33,707 09-15-2020, 03:42 PM
Last Post: voidmain
