Pinebook Pro Usb-C hub price
Question
Does anyone have an idea of about how much the Pinebook Pro usb-c hub will cost? I know the blog update said it is still in its early stages, but a rough estimate would be really nice.
Your probably better off not waiting if you need one now since it is in the early stages
I would recommend that you look at this one here if you already have a USB-C charger for your PBP
I can confirm this one works very well with the PBP, too:
https://www.anker.com/products/variant/p...b/A83380A1
(06-12-2020, 11:30 AM)tophneal Wrote: I can confirm this one works very well with the PBP, too:
Do the HDMI out and Ethernet work? Does the sound come through via HDMI? What OSes does this hub work in and which ones don't? This hub is exciting to see because it is the first affordable one I have seen that is verified to work on the PBP. Thanks for pointing it out!
I’ve only done partial testing, with manjaro and fedora. Ethernet works well, hdmi works but I didn’t verify the audio
(06-13-2020, 08:24 AM)tophneal Wrote: I’ve only done partial testing, with manjaro and fedora. Ethernet works well, hdmi works but I didn’t verify the audio
Ok, thanks!
Any update on the HDMI audio? I'm looking to get this one but like to confirm that HDMI audio is working. Thanks.
(06-16-2020, 04:05 PM)Upokupo Wrote: Any update on the HDMI audio? I'm looking to get this one but like to confirm that HDMI audio is working. Thanks.
HI!
HDMI audio is actually broken in Manjaro and won't work.
HI!
Thanks for the information.
Any updates on the status of the Pinebook Pro USB-C dock?
- availability
- pricing
Looking forward to it!
  Replacement battery for PineBook Pro DrYak 5 6,780 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,997 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,541 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 4,157 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,685 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,652 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,173 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 211,988 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 13,643 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 12,081 12-27-2022, 03:31 PM
Last Post: samtux
