Battery not charging via AC Adapter
Hi -
My PBP arrived yesterday. Out of the box everything seemed to work. Battery discharged over night (I neglected to power off PBP, so today I plugged in the AC adapter. Battery began charging, and I left it to continue charging while I stepped away. A couple hours later, I return to see the battery has stopped charging, and remains in a discharging state whether the AC adapter is connected or not. I've tried power cycling the PBP but that hasn't resolved the issue.
I just tested connecting to a USB-C dock and can confirm that PBP does draw power via USB-C, so it appears to just be the AC adapter. Any suggestions for how better to determine whether it's a faulty adapter or a problem with the port in the PBP?
(05-29-2020, 07:16 PM)laissezfarrell Wrote: Hi -
Please using multimeter to measure the power adapter whether has 5.3V output.
  Charging problem RicTor 4 3,070 07-28-2026, 08:10 PM
  PineNote v1.2 - Charges Never Enter "Charging" State (Factory OS, RK817 Below Minimum ttsp 0 1,662 07-02-2026, 02:52 AM
Last Post: ttsp
Photo P{inebook Pro not charging Ome Ko 6 7,593 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 14,432 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Pinebook Pro drains ny battery after shutting it off Tongman 4 7,256 12-01-2022, 02:50 AM
  Battery Frost1776 1 3,342 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 7,932 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 7,158 09-09-2022, 08:13 PM
  No audio from HDMI with usb-c adapter rfm83 5 15,763 06-19-2022, 09:06 PM
Last Post: rfm83
  Article: Build a Linux Driver for PineDio LoRa SX1262 USB Adapter lupyuen 3 7,448 05-26-2022, 11:09 PM
Last Post: lupyuen
