wlan0 missing
Hello there,
I just received my PineBook Pro today. I noticed that the wlan0 device is missing. I try the kill switch a couple of times like I red on other threads, but unsuccessfully.
inxi -Fxz gives out for Network: Message: No ARM data found for this feature.
Any suggestion?
Take a look here: https://forum.pine64.org/announcements.php?aid=32
(05-28-2020, 02:57 PM)Luke Wrote: Take a look here: https://forum.pine64.org/announcements.php?aid=32
I’m also experiencing the same and have tried disabling and enabling the kill switch and rebooting.
I appreciate the PSA Luke as I just received my PBP hours ago! After the privacy tweak, WIFI is working now. I also had to tweak my right-click trackpad settings.
As a follow up I was a bit confused by the wording in the wiki. I believe that 2 blinks = enabled meant that the killswitch was enabled, not the WiFi. I've gone ahead and edited the wiki for that section in hopes to maybe make it less ambiguous.
Good Smile
Thanks for your replies.
FYI I tried to boot a Debian image from a microSD card. Wifi worked not well, but gave a sign of life. So this was no kill switch issue. After that Manjaro worked like a charm.
  wifi missing some networks filip 0 1,649 03-11-2023, 03:21 PM
Last Post: filip
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 3,720 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Lid magnet missing? ModemBlaster 18 26,120 10-13-2020, 08:39 AM
Last Post: PineyMike
  Missing Screws missingchip 2 6,398 06-06-2020, 04:08 PM
Last Post: missingchip
  Pinebook missing screw from the factory tso4ev 4 8,722 01-20-2020, 01:25 PM
Last Post: Arwen
