LTE support.
It would be very beneficial if next version of PBP would include a sim card slot and LTE modem built in.
I use my current PBP for daily driver bussines laptop and hate the dongle sticking out. I am looking in a way to put it inside of case and add antennas.
Would buy another one if it had lte support built in.
PBPs do have a PCIe m.2 slot. The question is: Are there ARM64 Linux drivers for any such hardware or LTE modems that will fit in it?
Update:
Some quick googling found that 4g LTE modems in PCIe M.2 form factor go for about $30 USD. Now the question is only the drivers.
Please note that M.2 slots come in many flavors. The existing Pinebook Pro PCIe M.2 slot adapter is PCIe only, type M or M&B cards only.
There is a project to create a different flavor of M.2 card adapter;
WiFi 6 for the Pinebook Pro
It may show WiFi 6, but there is talk about other types of cards.
That is one nice thing about the Pinebook Pro, the ability to create other adapter cards.
Or multi-function cards. Or even 2 separate cards, right & left.
Arwen Evenstar
Princess of Rivendale
You can buy M.2 Key B LTE cards at Think penguin. Since they are a Linux hardware vendor, you can ask for support.
https://www.thinkpenguin.com/gnu-linux/4...ast-africa
https://www.thinkpenguin.com/gnu-linux/4...merica-usa
(05-08-2020, 07:45 PM)salteddoughnut Wrote: You can buy M.2 Key B LTE cards at Think penguin. Since they are a Linux hardware vendor, you can ask for support.
They won't work as is, because the Pinebook Pro NVMe M.2 adapter card does not supply a SIM card slot. The site has this warning;
Quote:SIM             Slot No (your system must have a SIM slot to utilize the card)
Further, the site does not specify if the M.2 Key B card uses PCIe only. B slotted cards have this available;
Quote:PCIe ×2, SATA, USB 2.0 and 3.0, audio, UIM, HSIC, SSIC, I2C and SMBus
[url=https://en.wikipedia.org/wiki/SMBus][/url]The LTE card could be USB 2.0 or USB 3.0.
Arwen Evenstar
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 331,436 09-27-2022, 07:41 AM
Last Post: olyavi
  [split] U-Boot with NVMe support, keyboard & display working as400 78 137,524 01-27-2021, 12:48 AM
Last Post: as400
  PBP problem and a silent support team pbp_user234 1 4,417 10-28-2020, 10:00 AM
Last Post: vfr400racer
Exclamation Pinebook Pro worst support ever gentux 10 18,482 09-27-2020, 11:19 AM
Last Post: LinAdmin2
  Pinebook Pro Support robheaton 2 5,856 09-15-2020, 01:08 AM
Last Post: robheaton
  How do I get official support? dream 4 9,607 01-05-2020, 06:08 PM
Last Post: dream
  Command line flashing script with media verification, xz image support Arglebargle 2 7,173 12-19-2019, 09:25 PM
Last Post: Arglebargle
