RealVNC and root password
I want to install RealVNC. Downloaded RealVNC deb package. Gdebi installer asks for password. Won't accept "rock"... invalid password.
So... what is the real root password?
(01-11-2020, 03:49 PM)mspohr Wrote: I want to install RealVNC. Downloaded RealVNC deb package. Gdebi installer asks for password. Won't accept "rock"... invalid password.
Edit the link and add gksudo in front of the command.
Hello, you can try NoMachine, who works "out of the box".
Try the armhf version. Very good software, free as in "free beer", no "free software".
Pinebook Pro, standard config (Manjaro)
(01-12-2020, 09:15 AM)regivanx Wrote: Hello, you can try NoMachine, who works "out of the box".
Thanks. I'll give it a try.
I did find out that there is a root password. I used root/root and was able to install it.
Thanks for the suggestion.
I managed to install Nomachine on Manjaro by downloading this version and following these instructions.
There seems to be a patch pending to make Nomachine available on Manjaro Pinebook pro.
Warning! This installation is purely empirical! But it works.
(04-16-2020, 03:14 AM)regivanx Wrote: I managed to install Nomachine on Manjaro by downloading this version and following these instructions.
Just as an update - I was looking at this today as a means of replacing VNC for connecting to my home server - worked fine but wanted to do 360 video editing on my Pinebook Pro and wanted to add sound Smile
Installing from AUR worked like a charm no problems.
Update: on Manjaro linux, install this version with the same instructions.
  Password reset or recovery tessa 2 5,147 11-11-2024, 04:27 PM
Last Post: tessa
  Nethunter default password failed lamlarryyyy 0 4,307 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  Encrypted Root jaredoconnor 1 3,158 01-19-2023, 02:27 PM
Last Post: Cs137
  Arch Linux ARM root filesystem SKiljan 24 47,789 09-24-2022, 03:11 AM
Last Post: alexandre
  suddenly the terminal won't accept me as root hayduke 1 3,305 09-21-2022, 07:37 PM
  Kali Linux password fail Wawe 5 13,441 03-23-2021, 11:09 AM
Last Post: Wawe
  Manjaro Crashes after entering password. chastitywhiterose 5 11,083 12-23-2020, 05:20 AM
  Root access over SSH enabled by default gibby 3 10,082 06-28-2020, 01:19 PM
Last Post: Arwen
  How to boot from eMMC but have root directory on an NVME? QazTheWsx 7 17,350 06-26-2020, 08:20 AM
Last Post: QazTheWsx
  @ in password hdk 0 3,551 11-04-2019, 02:22 PM
Last Post: hdk
