Installing WPS Office on Manjaro
As I personally do not like the Libreoffice suite, and I don't mind too much using software that is not FOSS if it's a better match for me, I managed to get WPS Office running on the PBP running Manjaro, and it works really smoothly! The PKGBUILD and accompanying files are attached. This is just a minor adaption from the x86_64 AUR PKGBUILD.
Enjoy!
[Image: 7de42a784c0bcb8d911184ee24f9e46a.png]
.zip   wps-office.zip (Size: 100.27 KB / Downloads: 980)
(03-08-2020, 09:47 AM)brent.thierens Wrote: As I personally do not like the Libreoffice suite, and I don't mind too much using software that is not FOSS if it's a better match for me, I managed to get WPS Office running on the PBP running Manjaro, and it works really smoothly! The PKGBUILD and accompanying files are attached. This is just a minor adaption from the x86_64 AUR PKGBUILD.
Enjoy!
That worked great! How do I update it? When I clicked the update button it only took me to a Chinese page. I am TOTALLY new to this PKGBUILD thing, but I'm learning... Smile
You can go to their main website: https://www.wps.cn/product/wpslinux/
The you hit the big blue button (it says download or something) and then you copy the download link for arm .deb
And then you should be able to update the PKGBUILD, both the source link and the checksum Smile
For those interested, you can achieve the same using the wps-office-cn package from the AUR. Although it says cn, it should be in English as well, depending on your system locale. The software itself is a bit different compared to the international version, but it is the only version that is available for ARM
Is this software compatible with Microsoft office files? I am quite interested in using this.
The compatibility is never perfect, even between different MS Office versions themselves, but it does a quite good job at being compatible yes.
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,946 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 25,026 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 6,637 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 13,124 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,616 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 5,146 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 89,348 07-28-2020, 03:18 PM
Last Post: SamWilts
  kernel build script for latest mainline manjaro kernel xmixahlx 42 95,608 07-11-2020, 09:01 PM
Last Post: xmixahlx
  full disk encryption with luks on manjaro xfce limxr 48 112,859 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 13,736 06-23-2020, 12:41 AM
Last Post: pljanson
