[wiki] changed or charged? -one char, but far important consequences ;)
Hi There,
I may be wrong, but just saw from wiki
just 3rd paragraph in "BraveHeart" PinePhone Unboxing and First Time Preparation Guide".
Should be:
Quote:If you power on the phone the factory test image will boot. RTL8723CS (WiFi modem) will fail unless there is a WiFi network in range for it to see and the battery is charged. EG25 will fail until battery is changed.
Or
Quote:If you power on the phone the factory test image will boot. RTL8723CS (WiFi modem) will fail unless there is a WiFi network in range for it to see and the battery is charged. EG25 will fail until battery is charged.
I can't edit this memo in wiki.
Cheers
sorted Smile
  Fix Fake 0% Battery(charged with USB power) Shutdown biketool 0 3,073 04-17-2025, 04:11 AM
  Mobian PIN changed after update! Mwo87 21 35,605 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Is it normal for the pinephone to "discharge" after fully charged on multiple OS? Shad190 2 3,902 05-10-2023, 10:37 PM
Last Post: Shad190
  Pinephone pro and consequences for pinephone users ivanB1975 25 35,720 11-09-2021, 12:57 AM
Last Post: ryo
  list of linux native apps/softwares for pinephone on the wiki alexandre 7 17,456 10-26-2021, 11:56 PM
Last Post: bcnaz
  Changed pin to blank and can't get into phone now. umop 7 9,525 10-14-2021, 05:16 AM
Last Post: megous
Exclamation GPS is broken! Change wiki and page! And where is the antenna ? jack1 4 8,125 03-23-2021, 07:22 AM
Last Post: jack1
  Changed pw in terminal to 'asd' can't log in at phone's home screen now LazyMechTech 4 8,789 11-30-2020, 06:14 PM
Last Post: ryo
  Contribute tu Pine64 wiki p1trson 3 6,440 11-24-2020, 05:12 AM
Last Post: evilbunny
