OMV Rock64
I have a 3.5 inch HDD connected to ROCK64 via a powered dock. What is the proper way of turning off OMV installation ? Everytime I start, I get some error message, volume was not unmounted properly, could be corrupt message. How do i fix this ?
(02-20-2020, 10:16 AM)Nerevarine Wrote: Hi,
It's the dock, use one of these instead.
https://www.ebay.com/itm/USB-3-0-to-2-5-...fa|iid%3A1
https://www.amazon.in/ORICO-USB3-0-Clone...R7NRRXSDKG
I use this, can you tell me what I need to look for, to get a new dock ?
So, I downloaded and flashed the lasted "stable" version of OMV.
I've logged in and created a new password as prompted.
I followed the instructions to update and upgrade.
However, I can't seem to connect to the OMV via HTTP. I am missing something I believe...Please help?
(02-20-2020, 11:33 AM)Nerevarine Wrote: https://www.amazon.in/ORICO-USB3-0-Clone...R7NRRXSDKG
You need to get a sata to usb adapter that has power, since you are using a 3.5 inch drive. Or just replace the 3.5 inch drive with a 2.5 inch drive and an unpowered sata to usb adapter.  The rock64 doesn't have enough power to spin up a 3.5 inch drive but one or sometimes 2 2.5 inch drives aren't a problem.  A regular dock may also work, I have a single drive dock and don't get that error, but I'm not using it on a regular basis.  The ebay link i sent you is all you need, the offline clone feature on the dock you have is more than likely what is causing your issue.  That dock is more than just a sata to usb adapter.
Actually I'm aware that you need an external powered dock. The one I linked is externally powered, supports UASP and doesn't have electric backflow..
Please tell me what I should be looking for when buying new dock as eBay.com doesn't deliver here in my country
(02-20-2020, 10:25 PM)Nerevarine Wrote: Actually I'm aware that you need an external powered dock. The one I linked is externally powered, supports UASP and doesn't have electric backflow..
You should be looking for a basic adapter that has it's own power supply.
https://www.amazon.com/Benfei-Adapter-Co...WNrPXRydWU=
Okay, I checked the error logs and it is mmcblk1 refers to the memory card, not the HDD.
Can anyone tell me if you guys faced the same issue with your memory card ?
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,456 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 95,144 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 20,863 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,931 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,269 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,262 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,852 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,030 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,917 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 116,598 09-01-2024, 06:05 AM
Last Post: RaymondDay
