2020-02-20 Plasma Mobile image
Managed to make a call from the new pmos/Plasma image, I had to select the correct configuration in the sound setting and the Audio was quite distorted.
Has anyone else come across this?
The incoming audio is a bit weird yes, still figuring out why
(02-24-2020, 04:51 PM)MartijnBraam Wrote: The incoming audio is a bit weird yes, still figuring out why
Cool, thanks for letting me know. With a device like this there is always the worry that it came defective or worse that I broke it mucking about!
I advise everyone to update their system.
apk update && apk upgrade --available
(note the "--available" argument)
We now have Qt 5.14.1 in postmarketOS!
(02-25-2020, 04:00 AM)PureTryOut Wrote: I advise everyone to update their system.
Doesn't start at all now
Well, give me some logs! Any errors should be reported in "~/.xsession-errors".
It works for me :tm:
(02-26-2020, 01:26 AM)PureTryOut Wrote: Well, give me some logs! Any errors should be reported in "~/.xsession-errors".
Looks like the update spoils the root partition, I'm not even able to mount it on my laptop,  so it's probably not Qt update related.
fsck doesn't help.
I tried this twice with different SD cards.
I flashed the image using DD and resized the partitions using KDE disk utility to use the whole space.
I'm not sure then, that can't happen really.
Btw if you want the image to use all the available space, it's better to create your own image rather than using the pre-built ones. Use pmbootstrap and make the image with the "--sdcard /path/to/sd/card/on/pc" parameter. It'll automatically take up all space available.
#19
not a reply org.freedesktop.locale1 QDBusMessage(type=Error, service="org.freedesktop.DBus", error name="org.freedesktop.DBus.Error.ServiceUnknown"
, error message="The name org.freedesktop.locale1 was not provided by any .service files", signature="s", contents=("The name org.freedesktop.local
e1 was not provided by any .service files") )
Error relocating /usr/lib/libkwin.so.5: _ZN22QDBusAbstractInterface11doAsyncCallERK7QStringPK8QVariantm: symbol not found
Error relocating /usr/lib/libkwin.so.5: _ZNK20QFutureInterfaceBase5mutexEi: symbol not found
Error relocating /usr/lib/libKF5WaylandClient.so.5: _ZNK20QFutureInterfaceBase5mutexEi: symbol not found
Error relocating /usr/lib/libKF5WaylandServer.so.5: _ZNK9QFileInfo13symLinkTargetEv: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN20QTextStreamFunctions3decER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate3dayE9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN20QTextStreamFunctions4endlER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar19standaloneMonthNameERK7QLocaleiiNS0_10FormatTypeE: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN20QTextStreamFunctions3hexER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate9dayOfWeekE9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate4yearE9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar11daysInMonthEii: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN15QDateTimeParser11setCalendarERK9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN9QCollatorC1Ev: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK14QObjectPrivate17isSignalConnectedEjb: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar13partsFromDateE5QDate: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate9addMonthsEi9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QFileInfo13symLinkTargetEv: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate8addYearsEi9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate10startOfDayEN2Qt8TimeSpecEi: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN5QDateC1Eiii9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN20QTextStreamFunctions9forcesignER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK7QLocale8toStringERK9QDateTime11QStringView9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN20QTextStreamFunctions11noforcesignER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar12monthsInYearEi: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar13dateFromPartsERKNS_12YearMonthDayE: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate5monthE9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate11daysInMonthE9QCalendar: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar19maximumMonthsInYearEv: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZN9QCalendarC1Ev: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK9QCalendar9dayOfWeekE5QDate: symbol not found
Error relocating /usr/lib/libQt5Widgets.so.5: _ZNK5QDate8endOfDayEN2Qt8TimeSpecEi: symbol not found
Error relocating /usr/lib/libkwin4_effect_builtins.so.1: _ZNK20QFutureInterfaceBase5mutexEi: symbol not found
Error relocating /usr/lib/libKF5Plasma.so.5: _ZN22QDBusAbstractInterface11doAsyncCallERK7QStringPK8QVariantm: symbol not found
Error relocating /usr/lib/libKF5Plasma.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5Quick.so.5: _ZN20QTextStreamFunctions3decER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Quick.so.5: _ZN20QTextStreamFunctions4endlER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Quick.so.5: _ZN20QTextStreamFunctions3hexER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Quick.so.5: _ZNK14QObjectPrivate17isSignalConnectedEjb: symbol not found
Error relocating /usr/lib/libQt5Quick.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5Quick.so.5: qt_resourceFeatureZlib: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN15QRecursiveMutexD1Ev: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN14QMetaCallEventC1EttPFvP7QObjectN11QMetaObject4CallEiPPvEPKS0_ii: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN20QTextStreamFunctions3hexER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN15QNetworkRequestC1Ev: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN20QTextStreamFunctions5rightER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN9QtPrivate12argToQStringE13QLatin1StringmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN20QTextStreamFunctions3decER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Qml.so.5: _ZN15QRecursiveMutexC1Ev: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN15QRecursiveMutexD1Ev: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions3hexER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions10noshowbaseER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions9forcesignER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN23QCoreApplicationPrivate12addQtOptionsEP5QListI18QCommandLineOptionE: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions11noforcesignER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZNK6QLineF10intersectsERKS_P7QPointF: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions4endlER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions3decER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN15QRecursiveMutexC1Ev: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: _ZN20QTextStreamFunctions8showbaseER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Gui.so.5: qt_resourceFeatureZlib: symbol not found
Error relocating /usr/lib/libQt5Svg.so.5: _ZN20QTextStreamFunctions4endlER11QTextStream: symbol not found
Error relocating /usr/lib/libQt5Svg.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5QmlModels.so.5: _ZNK14QObjectPrivate17isSignalConnectedEjb: symbol not found
Error relocating /usr/lib/libQt5QmlModels.so.5: _ZN9QtPrivate12argToQStringE11QStringViewmPPKNS_7ArgBaseE: symbol not found
Error relocating /usr/lib/libQt5TextToSpeech.so.5: _ZN11QJsonObject6insertE13QLatin1StringRK10QJsonValue: symbol not found
Error relocating /usr/bin/kwin_wayland: _ZNK9QFileInfo13symLinkTargetEv: symbol not found
"/usr/bin/kwin_wayland" ("--xwayland", "--libinput", "--inputmethod", "maliit-server", "--exit-with-session=/usr/lib/libexec/startplasma-waylandsession") exited with code 127
startplasmacompositor: Shutting down...
startplasmacompositor: Done.
#20
~/.xsession-errors:
not a reply org.freedesktop.locale1 QDBusMessage(type=Error, service="org.freedesktop.DBus", error name="org.freedesktop.DBus.Error.ServiceUnknown", error message="The name org.freedesktop.locale1 was not provided by any .service files", signature="s", contents=("The name org.freedesktop.locale1 was not provided by any .service files") )
No backend specified through command line argument, trying auto resolution
kwin_core: Platform does not support input, enforcing libinput support
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5092:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5094:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5096:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5100:47: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5102:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5110:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5114:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5116:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:45: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5123:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: created compose table from locale C with path /usr/share/X11/locale/en_US.UTF-8/Compose
kwin_core: KGlobalAcceld inited
kwin_core: Session path: "/org/freedesktop/ConsoleKit/Session1"
kwin_core: "ConsoleKit"  seat: "Seat2" / "/org/freedesktop/ConsoleKit/Seat2"
kwin_core: Gained session control
kwin_wayland_drm: Did not find a GPU
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,019 11-18-2024, 02:23 AM
Last Post: linmob
  Gnome mobile user641 1 3,585 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 6,572 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,350 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 6,223 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,022 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  Disable mobile data auto-enable on boot 64_Tesseract 3 5,891 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 3,374 03-23-2021, 10:25 AM
Last Post: Egolep
  Where is the original PM OS image for Pinephone? mw4jet 1 4,779 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 10,730 02-28-2021, 02:20 PM
Last Post: MtnSk8
