Cant boot into home-rolled Arch Linux image
As a learning experience, I've been trying to roll my own Arch Linux image. I've been cobbling together bits and pieces from the following locations while adding some bits of my own:
  1. anarsoul's build scripts
  2. Blutkoete's manual setup
  3. hku2's manual setup
  4. enospc's mostly upstream uboot
Below is a copy of my image building script. My issue is, after writing the image to my SD card and rebooting, my pinebook pro boots into debian on the eMMC. I figure I must be missing some important component to the boot process on ARM but I have no idea what that is. Since the pinebook boots into debian without showing me any sort of error message, I don't know how to debug this. Does anyone see what I am missing, or does anyone know how to get some more info out of the pinebook during boot?
#!/usr/bin/env bash set -x set -euo pipefail IFS=$'\n\t' DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )" # Manual Steps ############## # # Install dirmngr # # trust arch linux arm key # gpg --recv-keys 68B3537F39A313B3E574D06777193F152BDBE6A6 WORKSPACE=$(mktemp -d -t "arch-pinebook-pro-build-XXXXXXX") cleanup() {    if [ -d "$MOUNT" ]; then        umount -R "$MOUNT" || true    fi    if [ -z "$LOOP_DEVICE" ]; then        losetup -d "$LOOP_DEVICE"    fi if [ -d "$WORKSPACE" ]; then rm -rf "$WORKSPACE" fi } trap cleanup EXIT DOWNLOADS="$WORKSPACE/downloads" mkdir -p "$DOWNLOADS" ROOT="$WORKSPACE/root" mkdir -p "$ROOT" MOUNT="$WORKSPACE/mount" mkdir -p "$MOUNT" IMAGE_FILE="$WORKSPACE/archlinux.img" IMAGE_SIZE="$(( 1024*1024*1024*6 ))" # bytes archroot() {    CHROOT="$1"    shift 1    CMD="$@"    mount -o bind /tmp "$CHROOT/tmp"    mount -o bind /dev "$CHROOT/dev"    chroot "$CHROOT" mount -t proc proc /proc    chroot "$CHROOT" mount -t sysfs sys /sys    chroot "$CHROOT" "$CMD"    chroot "$CHROOT" umount /sys    chroot "$CHROOT" umount /proc    umount "$CHROOT/dev"    umount "$CHROOT/tmp" } wget -O "$DOWNLOADS/base.tar.gz.sig" http://os.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz.sig wget -O "$DOWNLOADS/base.tar.gz" http://os.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz gpg --verify "$DOWNLOADS/base.tar.gz.sig" "$DOWNLOADS/base.tar.gz" # Disk positions (in bytes) sector_size=512 boot_start=$((1024*1024*20)) boot_size=$((1024*1024*1024*1)) main_start=$((boot_start + boot_size + sector_size)) dd if=/dev/zero of="$IMAGE_FILE" bs=1 count=0 seek=$IMAGE_SIZE fdisk "$IMAGE_FILE" <<EOF o n p 1 $((boot_start/sector_size)) +$((boot_size/sector_size)) t c n p 2 $((main_start/sector_size)) t 2 83 a 2 w EOF LOOP_DEVICE=$(losetup -f) losetup -P $LOOP_DEVICE $IMAGE_FILE dd if="$DIR/idbloader.img" of=$LOOP_DEVICE seek=64 conv=notrunc dd if="$DIR/u-boot.itb" of=$LOOP_DEVICE seek=16384 conv=notrunc mkfs.vfat -n BOOT -F32 ${LOOP_DEVICE}p1 mkfs.ext4 -L ARCH ${LOOP_DEVICE}p2 mount ${LOOP_DEVICE}p2 "$MOUNT" mkdir "$MOUNT/boot" mount ${LOOP_DEVICE}p1 "$MOUNT/boot" # bsdtar too old on base pinebook install #bsdtar -xpf "$DOWNLOADS/base.tar.gz" -C "$MOUNT" tar -xpf "$DOWNLOADS/base.tar.gz" -C "$MOUNT" # no genfstab on base pinebook install, do in chroot instead # genfstab -U "$MOUNT" >> "$MOUNT/etc/fstab" mv "$MOUNT/etc/resolv.conf" "$MOUNT/etc/resolv.conf.bak" cp /etc/resolv.conf "$MOUNT/etc/resolv.conf" cat > "$MOUNT/chroot_commands" <<EOF #!/usr/bin/env bash set -x set -euo pipefail IFS=$'\n\t' pacman-key --init pacman-key --populate archlinuxarm killall -KILL gpg-agent pacman -Syu --noconfirm # wget to fetch manjaro packages # arch-install-scripts for genfstab pacman -S --noconfirm wget arch-install-scripts mkdir /manjaro_packages pushd . cd /manjaro_packages wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/core/linux-pinebookpro-5.5.0-3-aarch64.pkg.tar.xz" wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/core/uboot-pinebookpro-2020.01-4-aarch64.pkg.tar.xz" wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/community/pinebookpro-post-install-20200203-1-any.pkg.tar.xz" wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/community/ap6256-firmware-2020.01-1-aarch64.pkg.tar.xz" pacman -U linux-pinebookpro-5.5.0-3-aarch64.pkg.tar.xz pacman -U uboot-pinebookpro-2020.01-4-aarch64.pkg.tar.xz pacman -U pinebookpro-post-install-20200203-1-any.pkg.tar.xz pacman -U ap6256-firmware-2020.01-1-aarch64.pkg.tar.xz popd genfstab -U / >> /etc/fstab # clean up #yes | pacman -Scc EOF chmod +x "$MOUNT/chroot_commands" archroot "$MOUNT" "/chroot_commands" rm "$MOUNT/chroot_commands" mv "$MOUNT/etc/resolv.conf.bak" "$MOUNT/etc/resolv.conf" sync umount -R "$MOUNT" losetup -d "$LOOP_DEVICE" cp $IMAGE_FILE "$DIR/archlinux.img"
Its worth noting that when I write the official manjaro image to the SD card, it does boot that successfully.
Anarsoul only release Pinebook build and not aware he has make one for Pinebook Pro. My takes you are using wrong build.
Thanks for replying, but I am not using his image. That list was a set of sources where I'm pulling information from. The image I'm generating is from my own script which I pasted above. In the script, I install the manjaro kernel for the pinebook pro and my uboot image is from a blog post for building uboot specifically for the pinebook pro. Is there another machine-specific part of the boot process that I'm missing?
You have root on a different partition than boot, so you need to modify /boot/boot.txt and run mkscr. You may also need to modify mkinitcpio.conf
This has helped me:
https://github.com/lsfxz/pinebookpro-thi...aster/luks
Ah thank you! As a temporary measure to test this, I moved everything down to 1 partition which worked. Now I just need to learn how to properly modify boot.txt for multiple paritions, but now that I have a working state to iterate from, that should be much easier. I'll have a look at that github repo.
  Boot Order in Pinebook Pro food 14 19,331 Yesterday, 08:39 PM
Last Post: noahclark
  Can’t login to Linux fnosai 0 3,431 07-27-2025, 12:30 AM
Last Post: fnosai
  What's a good image to use now? [tutorial help as well] frank_philip 40 32,869 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 18,267 03-10-2025, 01:55 PM
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,456 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 7,049 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,707 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 4,141 06-05-2024, 04:30 PM
Last Post: vxzero
  By the way, yay arch... KC9UDX 4 6,084 03-30-2024, 10:27 PM
  Pinebook Pro upgrading from the factory image yamsoup 12 17,849 02-22-2024, 04:02 PM
