Suspend state: discharge time
Question
My Pinebook Pro (default Debian) in suspend mode (power indicator LED is red) fully discharges (100% -> 0%) in less than two days.
This is normal?
>This is normal?
If suspend is not working right, yes
Manjaro, seems to be ~5%/day
(02-20-2020, 10:17 AM)wdt Wrote: If suspend is not working right, yes
As far as I understand (by red LED), suspend is works (factory Debian).
Manjaro ARM without a power cable does not work for a one day  Confused  May require battery calibration or something similar?
Your post is not so clear, maybe if it doesn't work well
https://forum.pine64.org/showthread.php?...48&page=19
I haven't checked stock yet, both versions of q4os sort of work,
but not well, wake up issues and not very good power saving
Debian10 seemed like no power saving at all, but since it has
manjaro kernel it probably could be made to work
you can configure the suspend state. it isn't going into a power saving state.
for the manjaro kernel they/we use s2idle deep, and suspendstate=mem. will be 2% power draw per day.
if you suspend, but your power light stays on it is unlikely to be setup for power savings.
the 4.4 kernel should support this configuration.
what are your outputs of:
cat /sys/power/mem_sleep
cat /etc/systemd/sleep.conf
So, I setup Debian10 like the link above, no real power saving, errors with emmc
Maybe because the kenel is not the same, deb10 5.4.2,, manjaro 5.5.0-3.1
--edit--
Manjaro seems to be a bit indeterminate, that is
sometimes the power saving is extremely good,
and sometimes only 1/2 that good. I am at a loss to explain
(02-22-2020, 11:42 AM)xmixahlx Wrote: what are your outputs of:
Manjaro ARM:
$ cat /sys/power/mem_sleep
s2idle [deep]
$ cat /etc/systemd/sleep.conf
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See systemd-sleep.conf(5) for details
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendMode=
SuspendState=freeze
#HibernateMode=platform shutdown
#HibernateState=disk
#HybridSleepMode=suspend platform shutdown
#HybridSleepState=disk
#HibernateDelaySec=180min
try suspendstate=mem and reboot.
I've been following. I'm Running Manjaro with KDE on a Pinebook Pro. The output of cat /sys/power/mem_sleep
cat /etc/systemd/sleep.conf is the same as EreTlk on my machine. When I try to edit etc/systemd/sleep.conf with suspendstate=mem the computer does not suspend. I end up with a blank screen with a mouse and have to hard reboot to get back in. I have tried "SuspendMode=mem" also but did not get the expected behaviour. Do you have any other ideas. Is suspend indeed working in Manjaro?
Thanks!
-Josh
SuspendMode=mem in my sleep.conf
Works fine, usually about 5%/day
No red led, only green (not talking about barrel plug,power plug)
I only enter/leave suspend with short power button press,,
all other keys and touchpad are dead when sleeping
It is unclear to me, at this point, interaction with uboot
(stock on emmc, manjaro on SD)
--edit, much later--
Just retested debian10 with updated kernel, no change re sleep
(effectively no power savings)
  PineNote v1.2 - Charges Never Enter "Charging" State (Factory OS, RK817 Below Minimum ttsp 0 1,272 07-02-2026, 02:52 AM
Last Post: ttsp
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,020 11-25-2024, 03:42 PM
  high battery drain on suspend/poweroff wiz 5 10,389 02-10-2022, 11:52 AM
  Power consumption and suspend to ram robt 33 72,549 11-30-2020, 04:32 PM
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 25,422 09-29-2020, 10:24 PM
  New Pinebook Pro, only boots 50% of the time micnd90 8 14,166 09-08-2020, 01:25 PM
  PBP running shipping Manjaro won't wake from suspend fornio 2 7,650 07-21-2020, 07:04 AM
Last Post: vancheese
  It's been fun, but time to sell chetchinglo 5 10,225 07-15-2020, 10:47 PM
Last Post: xmixahlx
  Suspend with NVME not working - Default Debian appdev46 5 15,200 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  Boot time text messges Pbowen 2 5,822 06-10-2020, 02:41 PM
Last Post: Pbowen
