Can the pinephone be powered without a battery?
I'd like to be able to power a smartphone device without the battery installed. Is this possible with the pinephone? Assuming by default it won't work (no phone after the galaxy S2 ever supported this), can the presence of a battery be faked such that it will work without damaging the device?
In case you're curious why: Intended application is to have it continuously powered near the head end of my bed where I will mainly use this device as a white noise generator and an alarm clock. I have currently gone through great trouble to rig up an LG Volt to do exactly this, but it relies on a questionable LineageOS build on the software end to work, and even more questionable methods to install said OS onto the phone. All in all it's a pain, and an open platform phone would be far more preferable.
(02-12-2020, 05:49 PM)stragulus Wrote: I'd like to be able to power a smartphone device without the battery installed. Is this possible with the pinephone?
Yes, see the wiki. Without any tweaks you are OK but have no modem, wifi or BT.
Promising! So in order to get everything working, one has to provide 3.8V through the battery terminals with enough current?
Why not just leave the battery in and have it continuously charging?
(02-13-2020, 03:47 AM)Boern Wrote: Why not just leave the battery in and have it continuously charging?
I hope the charge control strategy's better than that or our battery capacity will degrade faster than necessary, but I agree with the principle. The battery gives you a built in UPS n case of a power cut or glitch.
I had to try and see if it would work. As mentioned above, WiFi isn't working.
https://i.imgur.com/1R1ezMz.jpg
Batteries degrade faster if you do that, but more importantly it's right next to my head at night and I'd rather not have a high-energy prone-to-failure device so close to me.
Quote:I had to try and see if it would work. As mentioned above, WiFi isn't working.
Thanks for testing, that is good to know.
  Battery life improvement freelectro 11 12,984 09-14-2026, 08:53 AM
Last Post: Juergen
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 23,547 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,548 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,151 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,551 01-20-2026, 01:43 PM
Last Post: Anna
  Battery connector dead mdk 5 5,289 01-15-2026, 02:24 PM
Last Post: mikeb
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 8,989 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,497 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,573 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,065 07-02-2025, 12:50 PM
