Charging issues and battery life
This is perhaps two issues.
1. The battery does not last very long. Perhaps this is because the display is kept on all the time displaying the time and etc.
2. When you plug it into USB and it is on, it does not seem to charge, so it eventually powers off. Then if you plug it back in, it will start charging.
1. As I understand it there is little to no powersaving features. I have not checked yet (but will try to remember to do) but my guess is that the cpu and gpu is running @full speed all the time. This along with screen on, wifi and modem on etc will ad up to maybe 2-3h of on screen time. Things will surely change in the future.
2. Make sure you use a good charger, 5V 3A is nice.
"- is there already a tool for overclocking it desperately?"
(02-12-2020, 12:55 PM)murak Wrote: 1. As I understand it there is little to no powersaving features. I have not checked yet (but will try to remember to do) but my guess is that the cpu and gpu is running @full speed all the time. This along with screen on, wifi and modem on etc will ad up to maybe 2-3h of on screen time.  Things will surely change in the future.
Well, something seems to be wrong here: The phone gets quite warm and will suck a 10,000 mAh power bank wit a 2A USB empty withing 2 hours (plus its own battery also).
PMOS did not do this to start with, only started after I played with it for a while. I wonder if there is one particular app that uses all this energy.
I suspect there are all kinds of permutations of chargers and OS installations that will make this hard to compare.
Nonetheless my limited 6p: pmOS/Plasma seems OK to me. With a USB dongle plugged in the charger (plain old, no PD) couldn't cope and the battery % was falling as I worked. Plugging the charger directly into PP gets % increasing. I have noticed pmOS/Plasma does screensave and eventually screenlock: during these phases battery charge increment is rapid.
So far I have been sitting with charger continually connected.
(02-12-2020, 02:22 PM)Zweitaktmotor Wrote: Well, something seems to be wrong here: The phone gets quite warm and will suck a 10,000 mAh power bank wit a 2A USB empty withing 2 hours (plus its own battery also).
This is rather silly, but it seems to me that mobile data is always on even if it is switched off in Settings. Any Android phone will run down its battery in the same way.
I am sure there is a terminal command, but I am not very good at this.
Ultimately, perhaps it needs an automatic switch between Wifi and mobile data, depending on availability.
possibly try using the cable that came with the phone if you are not already.
If it's plugged into a computer it will only get 5V 0.5A which is not enough to actually charge so it slowly discharges.
  Issues after installing latest PostMarket OS with POSH xen314 4 8,275 08-20-2023, 11:18 PM
Last Post: xen314
  Battery issues user641 3 6,725 07-17-2023, 10:43 AM
Last Post: alaraajavamma
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,645 02-17-2023, 02:41 PM
Last Post: britelite
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 5,093 02-11-2023, 08:19 AM
Last Post: acid andy
  Pinephone 64 PostMarketOS edition Battery problem Alejandro.SU 9 17,333 12-22-2020, 04:33 PM
Last Post: Alejandro.SU
  pmbootstrap issues IVp 3 10,743 09-24-2020, 02:24 AM
Last Post: Pinethom
  should charging through the USB hub work? desca 1 4,919 09-17-2020, 02:35 PM
Last Post: desca
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 5,482 08-24-2020, 06:34 AM
Last Post: PureTryOut
  Battery life and ways to improve - request for official statement p1trson 0 3,481 03-01-2020, 09:18 AM
Last Post: p1trson
