my pinephone battery is dead :/
Pretty much what the title said, dead as in 0v on the multimeter
what happened was I was testing Ubuntu Touch, had the bug where the wifi drops and can't be raised again. I didn't know yet you could turn the chip off and on again by hand so I shut the phone down (via the UT power button menu IIRC), the battery was over 90% charged according to the charge UI. That was a few days ago, when I picked the phone again yesterday, oops
Not sure it's relevant but I should also mention that when I first got the pinephone it wouldn't recognize the battery (it booted fine when hooked to a charger), I have since read people mentioning having problem with adhesive residue on the pins or the battery being wrongly sitted so I assume that's what happened (it resolved itself after a few sd card swaps, I imagine I ended up putting the battery in the correct position).
could it be the wifi chip not being shutdown properly that drained the battery flat despite the phone being off?
question number 2, shouldn't this have triggered some sort of overdischarge protection circuitry?
(02-12-2020, 11:17 AM)emptyfortress Wrote: Pretty much what the title said, dead as in 0v on the multimeter
Yes, it for sure have triggered the protection circuit inside the battery. It happened for me with PmOS  running om it, until the battery cut it off.
The battery can be charged again, but it only charges with about 100mA in the beginning, so just be patient.
thanks! I'll give it a try and report back.
That worked! marking as solved. Thanks Alho!
Sadly, this did not work for me. I've left the phone charging for three days now. Still nothing. I've tried two different chargers. Neither one is a fast charging power adapter. I knew the risks when I bought it. The only solution I can think of now is to buy another phone and to try to charge the same battery in the new phone.
https://www.amazon.co.uk/Universal-Batte...981&sr=8-5
Something like this should get you going again. There are many variations at amazon, ebay, aliexpress etc.
For me the phone did the job of charging from 'dead' when I used the old charger from a Nexus 5X.
(04-22-2020, 05:15 PM)wibble Wrote: https://www.amazon.co.uk/Universal-Batte...981&sr=8-5
That would do it alright. Thank you for the advice. I will get one straight away. I had been wondering if such a thing existed but did not find anything until you showed me.
I see that batteries is the only spare part that Pine64 does not provide worldwide because of shipping restrictions. I wonder if a universal battery charger with a battery inside could circumvent these restrictions. So far Pine64 has amazed me with their hardware, so I would not rule it out.
I managed to get some charge back in the battery by putting it in another phone (Cubot Dinosaur). That was enough for it to turn on the Pinephone and boot up the factory test suite.
  Pinephone - broken power button rorus 14 23,336 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Pinephone + Keyboard for sale, little use ruemoo 15 10,867 03-05-2026, 10:14 AM
Last Post: diazman39
  PinePhone 16 GB – Free to a Good Home Anna 2 1,380 01-20-2026, 01:43 PM
Last Post: Anna
  Battery connector dead mdk 5 3,909 01-15-2026, 02:24 PM
Last Post: mikeb
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 19,363 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,588 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 2,768 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,088 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,504 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 3,889 06-21-2025, 05:19 PM
Last Post: mikeb
