UBPorts Battery Observation
Has anyone noticed battery issues with UBPorts?
I received my PinePhone and tried out UBPorts.  I did upgrade and update and played around a bit.  The phone was charged to 100%.  I locked the screen and went to bed.  In the morning the battery was completely dead.
It appears the OS didn't go to sleep or something was running heavily enough to completely drain battery.
Yeah, I tried how long the battery lasts. About 7 hrs. The phone is also warm all the time. So it doesn't go to sleep. I think the power management is not there yet.
(02-07-2020, 08:28 AM)appdev46 Wrote: Has anyone noticed battery issues with UBPorts?
I have this problem not only under UBPorts but under PMOS too. The device gets extremely hot and the battery drains in a few hours.
I've noticed that the battery will only charge if I turn on the phone while it is plugged in. After the cord is unplugged charging will not work until the phone is restarted with the cord attached.
I definitely experienced this. Just got my PinePhone yesterday. The battery runs down quick, but hopefully it's something they can fix.
I think it´s with modem wifi activated, if not battery remains "normal" Modem gets hot also when activated...
Edit: tried last img and goes down quickly with and without wifi, modem. Some issues charging sometimes also.
(02-08-2020, 02:41 PM)mpnordland Wrote: I've noticed that the battery will only charge if I turn on the phone while it is plugged in. After the cord is unplugged charging will not work until the phone is restarted with the cord attached.
Ditto.
Did you remove the plastic between de contacts of the battery used for shipping the phone?
yesterday I left the pinephone in charge all night long, this morning it was100% full ; turned it off and unplugged from charger. This evening turned it on, but battery was at 0%!
I have a feeling the issue is:
https://wiki.pine64.org/index.php/PinePh..._connected
I don't really know, and I hope not as this would mean the Braveheart hardware will never be daily driver material...
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 12,316 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  online accounts in UBports Uturn 2 7,669 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 17,240 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 5,329 11-27-2020, 07:40 PM
Last Post: piney-tim
  UBPorts Convergence MonCon 0 4,058 11-24-2020, 04:25 PM
Last Post: MonCon
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 29,663 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 14,362 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  UBPorts doesn't boot even after booting into recovery defekto 2 8,146 09-30-2020, 12:16 PM
Last Post: defekto
  Dekko on UBPorts PinePhone usable? djvinniev77 13 25,870 09-17-2020, 03:45 PM
Last Post: yurievitch
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 34,092 09-15-2020, 03:42 PM
Last Post: voidmain
