Pine Phone no power up or just somtimes
Hello
I have receive my pinephone but i can't to power up (no led no lcd)
What is the problem, if i use lsusb command on ubuntu i can see :
Bus 001 Device 004: ID 1f3a:efe8 Onda (unverified) V972 tablet in flashing mode
Can i reflash postmarketos (bootloader) ?
Thanks in advance
exactly the same problem here...
Advice appreciated  Smile
Thanks!
https://wiki.pine64.org/index.php/PinePh...nformation
A slight possibility, loose battery connection?
(02-02-2020, 06:31 PM)dukla2000 Wrote: https://wiki.pine64.org/index.php/PinePh...nformation
Thank you for your suggestion. The same happens when the phone is connected with a USB cable, so I don't think it's a loose battery connection...
Remove the little tab between the battery and mainboard pins.
(02-03-2020, 05:03 AM)Luke Wrote: Remove the little tab between the battery and mainboard pins.
Thanks, tab is already removed.
Shot in the dark here, but do you press and hold the power button for >10 seconds? Mine requires 10 seconds.
"- is there already a tool for overclocking it desperately?"
(02-03-2020, 07:52 AM)murak Wrote: Shot in the dark here, but do you press and hold the power button for >10 seconds?  Mine requires 10 seconds.
Thanks for the suggestion murak, but that I tried already...
Do you have the original firmware for factory test ? to flash it please, i think this is the electronic card
pretty sure it's the loose battery. im having the same issues, I haven't managed to power it on without putting on the battery cover and pressing it very tightly to make sure the battery is in place. Put the phone in my backpack and went for a ride, that seems to have moved the battery and the phone was powered off until I could re-seat the battery properly.
  Pinephone visibly losing power while plugged in Hiraghm 9 9,010 08-29-2026, 11:18 AM
Last Post: baptx
  Power up a 2nd core? WhiteHexagon 1 1,579 01-03-2026, 02:24 AM
Last Post: WhiteHexagon
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,844 11-30-2025, 08:07 AM
  Default password for KDE plasma pine phone Toni 0 8,393 09-14-2025, 06:35 PM
Last Post: Toni
  Fix Fake 0% Battery(charged with USB power) Shutdown biketool 0 2,968 04-17-2025, 04:11 AM
  My new phone stopped working. gunnygee 3 4,822 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,323 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,372 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 6,802 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 9,230 03-14-2024, 03:51 AM
Last Post: MTXP
