Trackpad lack of fine movement and overrun ruining experience.
(01-30-2020, 03:45 PM)logicprobe Wrote: Same here. Living with it.
Me too!
Still a happy Pinebook Pro customer...
crocky
I am having the same issue on my ANSI PBP. I'm also having trouble getting "disable while typing"working in every distro except the default Debian. It didn't work in Bionic and it's not working in Manjaro KDE, and yes, I have applied the update.
I was messing around with synclient a bit, and found adjusting the MinSpeed setting to help out quite a bit with getting more precision - I'm not sure if it's the recommended way of doing it, but adding this to /etc/X11/xorg.conf allowed it to persist over reboots (in X11):
Section "InputClass" Identifier "touchpad catchall" Driver "synaptics" MatchIsTouchpad "on" MatchDevicePath "/dev/input/event*" Option "MinSpeed" "0.25" EndSection
(01-31-2020, 07:41 AM)jackhumbert Wrote: I was messing around with synclient a bit, and found adjusting the MinSpeed setting to help out quite a bit with getting more precision - I'm not sure if it's the recommended way of doing it, but adding this to /etc/X11/xorg.conf allowed it to persist over reboots (in X11):
If I don't have /etc/X11/xorg.conf in Debian Bullseye?
PBP ISO / Debian Bullseye (unofficial installer)
(02-01-2020, 01:24 PM)wasgurd Wrote: If I don't have /etc/X11/xorg.conf in Debian Bullseye?
Then create it (with exactly that content).
/var/log/Xorg.0.log should then show an entry about MinSpeed.
I can confirm that the minspeed setting is very helpful, even though I'm not using the alternative firmware. I'm using the update that was supposed to come on the ANSI devices but didn't. Grabbing screen corners is still a little tricky (I've been using trackpoints on my home and work computers for a decade so maybe I just need practice), but much easier than before. uMatrix is also much easier - those top/bottom buttons are a good test!
Thank you so much! The touchpad is usable now. Not perfect-perfect, but I can actually use it for other stuff than scrolling. Amazing!
I've built on your settings a little and have found these to be very good:
synclient MinSpeed=0.25
synclient FingerLow=30
synclient PalmDetect=1
synclient VertScrollDelta=64
synclient HorizScrollDelta=64
'FingerLow' has the same value as 'FingerHigh' in my config (30). I believe it helps reduce mouse movement as you lift your finger, but I'm not sure if synaptic works like this.
Anyway, I find this config to be comfortable for daily use. I'm still trying to find out how to stop the cursor from jumping around, whenever you put down the finger.
Let me know if anyone finds out some even better settings!
#19
my sway config has a basic config with good results: (sway-git, mesa-git, debian sid arm64)
input "9610:30:HAILUCK_CO.,LTD_USB_KEYBOARD_Touchpad" {
dwt enabled
tap enabled
natural_scroll enabled
middle_emulation enabled
#20
I tried to make these changes, but I think my x crashed. I ended up with a cursor. Using Manjaro. Trying to restore from SD, now.
  Trackpad firmware update Luke 263 600,371 07-28-2021, 12:52 PM
Last Post: Luke
  My Experience Using the Pinebook Pro as a Daily Driver warpnow 9 17,851 06-22-2021, 02:30 PM
Last Post: moonwalkers
  Trackpad film clockcycles 5 10,243 06-18-2021, 09:34 PM
  User experience quadrantids 14 23,548 03-26-2021, 05:06 PM
Last Post: dsimic
  Lifting Trackpad p3pp3r 7 15,877 03-23-2021, 05:48 PM
Last Post: Timpanogos Slim
  Selling Pinebook Pro 128GB version (w/ NVMe adaptor) due to lack of use VoT 3 8,113 03-19-2021, 03:11 AM
Last Post: jj282
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 15,220 12-30-2020, 06:14 AM
Last Post: BetteHoward
  Does this plastic trackpad cover come off? Paulie420 7 13,040 09-17-2020, 02:29 AM
  Mouse drfting when using the trackpad jcarty 1 4,922 09-15-2020, 03:21 PM
Last Post: ab1jx
  Trackpad sensitivity barn 1 4,790 08-06-2020, 01:03 PM
