Manjaro XFCE: Enable Natural Scrolling (Reverse scrolling direction)
Just thought I'd share for anyone else trying to figure this out. Enabling Natural Scrolling for Manjaro XFCE in the touchpad settings panel does not currently work. You can however, set it via the command-line according to the Arch Wiki. I'm not sure if this is the best/appropriate way to fix the issue, but it did work for me:
1. Using the package manager, install the xorg-xinput package, which contains the xinput utility
2. From the terminal, run the following command and note the ID number for the Touchpad:
xinput list
3. Run the following command and note the number for the property labelled "Natural Scrolling Enabled (<propertyID>)"  It should have a "0" next to it, indicating that it is disabled. Replace the <deviceID> with the ID for your Touchpad:
xinput list-props <deviceID>
4. Set the scrolling property to "1" (enabled) by running the following command, replacing <deviceID> with your Touchpad's ID and <propertyID> with the ID number for the natural scrolling property:
xinput set-prop <deviceID> <propertyID> 1
Note that this doesn't persist after a reboot, and the deviceID and propertyIDs appear to change. If you want to persist the changes, you will need to use the string names for the device and property in a .xprofile script in your home root.  For example:
#!/bin/bash xinput set-prop "HAILUCK CO.,LTD USB KEYBOARD Touchpad" "libinput Natural Scrolling Enabled" 1
Enjoy!
  How to enable widevine in firefox (PrimeVideo) sirspate 18 58,008 12-01-2023, 06:52 AM
Last Post: Tazdevl
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,772 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 24,577 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 6,461 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 12,882 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,437 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 5,080 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 16,465 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 94,595 07-11-2020, 09:01 PM
Last Post: xmixahlx
  full disk encryption with luks on manjaro xfce limxr 48 111,336 07-09-2020, 07:27 AM
Last Post: JtR
