Debian MATE update v1.6
For those running the default Debian image, Mrfixit has just released the v1.6 update, bringing an updated kernel (4.4.205) and graphical fixes for the included Firefox version.
Use the updater applet in the notification tray to update. Smile
(12-02-2019, 10:23 AM)fire219 Wrote: For those running the default Debian image, Mrfixit has just released the v1.6 update, bringing an updated kernel (4.4.205) and graphical fixes for the included Firefox version.
I lost the applet button when moving panels around. Does it do the same as sudo apt update && sudo apt dist-upgrade?
If not, what's the command to run the applet?
Thanks in advance
Thanks in advance
Looks like the command is:
mate-terminal -x sudo /usr/bin/mrfixit_update.sh
From a open terminal just "sudo /usr/bin/mrfixit_update.sh"
de KL7JKC
Terrific! Thanks!
Is anyone else finding that the script hangs on 'Adding bluetooth packages to fix issues...'?
It won't go beyond that for me.
(01-17-2020, 04:47 PM)ToPort Wrote: Is anyone else finding that the script hangs on 'Adding bluetooth packages to fix issues...'?
I waited for a long time then pressed the Enter key to see if it was possibly waiting for input?
Shortly after that the script completed normally.
Coincidence - you tell me?
Yeah, looks like a lack of patience on my part may have been the issue.
Of course often nothing solves a problem quite as efficiently as posting on a forum, then looking like an idiot...
Does the v1.6 update also switch to the Debian Buster repositories?
My Logs. It's a long list. Anything I can do about it?
.png   Logs2020-03-31 08-52-50.png (Size: 363.53 KB / Downloads: 734)
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,393 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,209 06-26-2025, 09:20 PM
Last Post: reukiodo
  Official Debian support moonwalkers 64 119,742 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 12,131 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,024 03-01-2024, 06:46 PM
Last Post: Puckla
  install debian on pbp jsch 7 12,028 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 22,860 09-07-2023, 09:38 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 4,782 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 4,562 05-10-2023, 04:51 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 4,916 01-25-2023, 09:12 AM
Last Post: myself600
