PBP Speaker Replacement
Hello PBP community,
This post to show my PBP speaker mod, 1st try.
I'll test some other speakers in the future, because while replacements are better than original, I still haven't found what I'm hearing for.
My appreciation of the stock speakers:
Bad sound, no bass at all, makes me feel cranky and uneasy, very disagreable.
2/10
New speakers: GHXAMP 20MM 4 Ohms 2 W
Average-to-good sound, little bass, would use to watch movies and listen to music if no other choice
7/10
Replacement went well, except for 1 thing: new speakers were about 2mm thicker than old ones. I had to move them farther from the sides a little, removing sidewalls in the process. I can confirm that while the BPB material feels like metal, it's plated over some plastic core. 2 sided tape was used to fix them in place. See attachments for replacement process pics.
In the process, I had to open the PBP for the 4th time. I'm afraid this isn't PBP friendly. Will have to imagine some bottom panel replacement hack soon. Would be nice to have a more thinkerer friendly choice shell design for next PBP iterations, even at the price of a thicker laptop. What should matter most is rigidity, stiffness and weight. Not trying to copy Mac Book laptop designs, which are, by the way, computers made for never being opened.
Sound test:
.jpg   0.jpg (Size: 193.57 KB / Downloads: 1,074)
.jpg   1.jpg (Size: 256.18 KB / Downloads: 1,091)
Creating is Everything
Away
This is an interesting post. How well do the speakers fit into the PBP case - I can' really tell from the picture. To make it more specific - I am curious about the height of the speakers. Thanks!
Music
(01-16-2020, 04:41 PM)Luke Wrote: This is an interesting post. How well do the speakers fit into the PBP case - I can' really tell from the picture. To make it more specific - I am curious about the height of the speakers. Thanks!
I've just edited my post to explain that. I neglected making a last inside pic of the mod, as I was distracted by some other things at the end. So I had to remove the side of the speaker sitting base, because new speakers were 2 mm thicker than old ones. Moving them about 3 mm closer to the PBP center was enough. The I used double sided tape for retention.
While I have not modified the shell speaker "grill", and some part of the speakers are not exposed the perforations, this does not affect sound levels, which are acceptable.
For my next test, I'll use some thinner and larger (maybe 3 to 4 cm) round or oval speakers, which should work well.
Will post again.
Cheers.
Away
Heart
I may have found better...
https://www.digikey.ca/product-detail/en...D/5958415/
http://www.puiaudio.com/pdf/AS01808AO-WP-R.pdf
1 W, 8 Ohms, full spectrum, 3 mm thin, 13 X 18 mm (should fit like gloves - regular PBP are 20 X 30 mm), solder pads, waterproof (not that we should care), and 94 DB !! (wow)
I think I'm in love. We'll keep you posted.
Away
(01-16-2020, 06:42 PM)8jef Wrote: I may have found better...
Following this, thanks for your effort  Smile
crocky
I have found better!
Review:
A bit thinner and smaller than stock speakers, less than 3 X 13 X 18 mm (stock 3 X 20 X 30 mm), these PUI Audio speakers (model AS01808AO-WP-R) represent a great improvement upon stock ones, and a marginally good improvement compared to my previous test, especially regarding bass sound. Then, there are no miracles. Good quality headphones are still much better. Another good point for the PUI's: they are a bit louder than the others. Finally, distortion will happen if you crank volume over 100%. Speakers from the first test were not as prone to distort sound, but then, there was less bass to begin with.
Fitting:
Applying double sided tape to the front contour of each speaker (pic 1), I was able to glue them directly over the mesh/grill areas on the bottom cover. I've then soldered (-) and (+) on both side (pic 2), before covering with electrical tape (pic 3). The finishing touch was to apply some thin foam layers with double sided tape just over each speaker to act as dampers inside the housing sandwich (pic 4).
That's about it.
Conclusion:
Sound challenges on the PBP, among others, are closely related to the choice of housing. Mac Book Air ultra thin housing style forbids from using better thicker fuller speakers, and/or other hardware. This makes other things difficult, like adequately fastening the bottom cover without breaking everything. Being already invested in the process of PBP hardware betterment, I'll next look for a way of designing and fitting some other better housing, tinkerer style. I have a few ideas in mind. I will come back with another thread once I have something to show you. Like minded spirits are welcome to PM me and/or post on the forum, so we can share solutions. Access to a large size 3D printer may help too.
.jpg   1.jpg (Size: 150.66 KB / Downloads: 1,030)
.jpg   2.jpg (Size: 164.48 KB / Downloads: 1,071)
.jpg   3.jpg (Size: 115.32 KB / Downloads: 986)
.jpg   4.jpg (Size: 132.89 KB / Downloads: 1,142)
Away
@8jef or @Luke, do either of you know the wattage and Ohms of the existing speakers?
Also, @Luke, could we get a datasheet for the existing speakers, to put on the Wiki?
Even if we can't get a datasheet, verification of the specifications would be helpful. For exactly this reason, replacement / modifications. I added the dimensions and that they are oval, but everything we can get, makes future work easier.
Arwen Evenstar
Princess of Rivendale
Information
(01-20-2020, 12:38 PM)Arwen Wrote: @8jef or @Luke, do either of you know the wattage and Ohms of the existing speakers?
I don't for sure. But I've found clones on eBay (and other platforms), and they are 8 Ohms 1W:
https://www.ebay.ca/itm/Repair-Part-Inte...4093172775
In my first test, I've used 4 Ohms 2W, and it worked well.
In the second test, 8 Ohms 1W, like stock.
Away
I'll try to get the datasheet for the speakers and upload it to Wiki . I'll notify you guys when / if I get the sheet on here.
(01-20-2020, 01:00 PM)Luke Wrote: I'll try to get the datasheet for the speakers and upload it to Wiki . I'll notify you guys when / if I get the sheet on here.
Thanks Smile
Although what help answer these sort of questions, and many other issues, is a Bill of Materials.
  Replacement battery for PineBook Pro DrYak 5 9,617 02-28-2026, 09:17 PM
  Replacement main board for Developers mozes 11 14,667 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 2,850 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 7,243 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 3,856 10-14-2024, 05:35 PM
  Battery replacement mjc 2 6,799 09-26-2023, 01:08 AM
Last Post: david-lechner
  Replacement scissor switches (ANSI keyboard)? zackw 3 8,452 08-09-2021, 09:20 PM
  Pinebook Pro/Pinetab replacement as400 11 22,205 07-30-2021, 04:40 AM
Last Post: as400
  Fix your Pinebook Pro speaker connection KC9UDX 12 22,008 07-08-2021, 02:10 AM
  Replacement board avaliability mrjay 1 4,889 07-06-2021, 04:08 PM
