Trackpad firmware update
(01-11-2020, 08:14 AM)Solra Bizna Wrote:
(01-10-2020, 04:35 PM)quantumape Wrote: Just got my PineBook Pro and ran the ANSI firmware update. Things are working pretty well but the trackpad has a peculiar behavior. It's like the mouse position is a couple steps behind the buffer for the trackpad. For instance, if I move left, then stop, then move up. When i start moving up, it goes left a little bit then up. It's just a bit behind and it doesn't update until new input to the trackpad is made.
If it's not just me, maybe I can help sort it out and post a patch? Very new to Pine and the hardware. If that is the case, would you have recommendations on where to start looking into the code? Very comfortable with hardware and mircocontrollers.
Really excited about this project, thanks everyone for their help and contributions!
I'm experiencing this problem too, and it's maddening. It's the last thing that's stopping me from using my shiny new PBP as my main machine—the trackpad is unusable like this. I have to assume it's not happening to most users or it would certainly have been noticed and fixed by now.
At some point I'm going to try just re-applying the firmware update, to see if that somehow fixes it. I've been too busy with other stuff until recently.
Yes ! I'm having this problem as well, even after applying the firmware update. I thought I was crazy since no-one else was reporting the issue. I found that playing with libinput parameters helps a bit, but it still seems there's something flaky about the trackpad itself.
Other users have reported these issues as well ( https://forum.pine64.org/showthread.php?...7#pid54297 )
The firmware for the touchpad is still the same binary blob from the november update. It seems plausible that qmk.fm firmware could be targeted to the pbp touchpad and keyboard, but personally, I don't know how to port qmk.
(11-22-2019, 09:42 AM)Luke Wrote: [edit 10/01/2020] FW flahing Instructions have been edited for both ISO and ANSI users now
Credit goes to @tllim , @xalius , @ayufan and @anarsoul
N.B. This trackpad/ keyboard firmware update applies to all Pinebook Pros produced in 2019
Before you start:
Your Pinebook Pro should be either fully charged or, preferably, running of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies.
Please report any issues you encounter in this thread.
What you'll need:
  • Your Pinebook Pro fully charged / running of mains power
  • Connection to WiFi
  • An external USB keyboard/ access to the Pinebebook Pro via ssh
What you need to do:
Please follow @ayufan's instructions exactly
Instruction Brief for BOTH models (read original instructions for further details):
ISO version
git clone https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater cd pinebook-pro-keyboard-updater sudo apt-get install build-essential libusb-1.0-0-dev xxd make
First Step:
sudo ./updater step-1 iso sudo reboot
Second Step:
cd /pinebook-pro-keyboard-updater sudo ./updater step-2 iso sudo reboot
ANSI version
First Step:
sudo ./updater step-1 ansi sudo reboot
Second Step:
cd /pinebook-pro-keyboard-updater sudo ./updater step-2 ansi sudo reboot
So, that was bad... My Pinebook seems bricked now.
Not even possible to complete the first step, after
I cannot even type sudo reboot because the keyboard has all letters wrong. Cannot even find a U Sad and mouse is gone too.
After force shutdown holding the power key, I boot into a black screen. I see the mouse pointer but cannot move it. Ctrl+Alt+F2 does nothing. I guess keys are still all wrong.
Does anyone see a way out of this????  Cry
@ravanh clearly you didn't read ayufan's instructions Smile I suggest you read them and, as its clearly stated, use an external keyboard + mourse / SSH for the update process
(01-13-2020, 10:39 AM)Luke Wrote: @ravanh clearly you didn't read ayufan's instructions Smile I suggest you read them and, as its clearly stated, use an external keyboard + mourse / SSH for the update process
Yeah, I see that last point now... my bad. So, is there a way out of this? Or have I just ruined my 300 dollars (incl. shipping and 60+ euro tax) not 1 hour after unpacking? That's really depressing :/
Don't worry, you haven't ruined anything. Just start over. Do step 1, reboot, step 2, reboot. Thats all.
I just got my ANSI PInebook Pro and installed this update.  Everything went smoothly and the trackpad works beautifully.  However, I notice that my '@' character is swapped with my '"' character on the keyboard (I have to shift + " to get @ and vice-versa for double-quote).  The update was one of the first things I did so I'm afraid I don't know if this was the state of affairs before the update.
Apologies if this is covered further up in comments.  I scanned a few pages but this thread is rather long.
@pjgruett,
Use the language selection of the OS to change from English UK to English US. I don't have the steps handy but that seems to have solved other peoples problems. (The Debian OS loaded, defaults to English UK because the originally weren't going to release an ANSI keyboard version of PBP.)
Arwen Evenstar
Princess of Rivendale
(01-13-2020, 05:47 PM)Arwen Wrote: @pjgruett,
That fixed it.  Many thanks!
i attempted to update my  4 hour old Pinebook Pro. Now I can't sign into Pinebook Pro using rock, rock. The letters typed not correct.
What can I do? Do I have to reinstall the OS or is my new Pinebook Pro bricked. Thank you for any assistance.
  Locked out after update Shylocked 5 5,763 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,726 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,276 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,139 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 6,870 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,770 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,474 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,746 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,285 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,602 11-18-2021, 06:37 PM
Last Post: reundo
