Rockpro64 and stock arch linux
I've gotten the stock rootfs running on the Rockpro64 SBC, using steps from a variety of sources. If desired, I'll try to hunt down the locations. Steps below:
Section 1 - Making a Good SPL
0. Perform these steps from a functional image, on the board, such as Armbian
    -note: may need to "apt-get install gcc-arm-none-eabi binutils-arm-none-eabi"
1. Get u-boot, cd into the folder
    #git clone https://gitlab.denx.de/u-boot/u-boot.git
    #cd u-boot
    #make clean
2. Get, make the Trusted code, copy it into the u-boot folder
    #git clone https://github.com/ARM-software/arm-trus...rmware.git atf
    #make -C atf PLAT=rk3399 bl31
    #cp bl31.elf ../
3. Make u-boot
    #make rockpro64-rk3399_defconfig
    #make ARCH=arm -j7
4. Write loaders to disk, or copy them to storage for Section 2
    #tools/mkimage -n rk3399 -T rksd -d tpl/u-boot-tpl-dtb.bin tpl-spl.img
    #cat spl/u-boot-spl-dtb.bin >> tpl-spl.img
    #dd if=tpl-spl.img of=/dev/mmcblkN seek=64 conv=fsync
    #dd if=u-boot.itb of=/dev/mmcblkN seek=16384 conv=fsync
Section 2 - Install Arch
0. This must be performed from a different computer, make sure uboot-tools is installed
1. Zero the beginning of the SD card:
    #dd if=/dev/zero of=/dev/sdX bs=1M count=32
2. Start fdisk to partition the SD card:
    #fdisk /dev/sdX
3. At the fdisk prompt, create the new partition:
    Type o. This will clear out any partitions on the drive.
    Type n, then p for primary, 1 for the first partition on the drive, 32768 for the first sector, and then +4G
    -this creates a 4G partition
    Write the partition table and exit by typing w.
4 . Create the ext4 filesystem:
    #mkfs.ext4 /dev/sdX1
5. Mount the filesystem:
    #mkdir something
    #mount /dev/sdX1 something
5. Download and extract the root filesystem (as root, not via sudo):
    #wget http://os.archlinuxarm.org/os/ArchLinuxA...est.tar.gz
    #tar -xpf ArchLinuxARM-aarch64-latest.tar.gz -C something
6. Use this as boot.txt, place in something/boot/
   # MAC address (use spaces instead of colons)
    setenv macaddr da 19 c8 7a 6d f4
    part uuid ${devtype} ${devnum}:${bootpart} uuid
    setenv bootargs console=ttyS2,1500000 root=PARTUUID=${uuid} rw rootwait
    setenv fdtfile rockchip/rk3399-rockpro64.dtb
    if load ${devtype} ${devnum}:${bootpart} ${kernel_addr_r} /boot/Image; then
      if load ${devtype} ${devnum}:${bootpart} ${fdt_addr_r} /boot/dtbs/${fdtfile}; then
        fdt addr ${fdt_addr_r}
        fdt resize
        fdt set /ethernet@fe300000 local-mac-address "[${macaddr}]"
        if load ${devtype} ${devnum}:${bootpart} ${ramdisk_addr_r} /boot/initramfs-linux.img; then
          # This upstream Uboot doesn't support compresses cpio initrd, use kernel option to
          # load initramfs
          setenv bootargs ${bootargs} initrd=${ramdisk_addr_r},20M ramdisk_size=10M
        fi;
        booti ${kernel_addr_r} - ${fdt_addr_r};
      fi;
    fi
7. in the something/boot/ directory, generate boot.scr from the boot.txt
    #mkimage -A arm -O linux -T script -C none -n "U-Boot boot script" -d boot.txt boot.scr
8. Unmount the partition
    #umount something
9. Write the bootloader to the sd card
    #dd if=tpl-spl.img of=/dev/sdX seek=64 conv=fsync
    #dd if=u-boot.itb of=/dev/sdX seek=16384 conv=fsync
10. Insert SD, apply voltage
11. Initialize the pacman keyring and populate the Arch Linux ARM package signing keys:
    #pacman-key --init
    #pacman-key --populate archlinuxarm
12. Update
    #pacman -Syu
    #pacman -S uboot-tools
Further Notes: hdmi may be kinda weird from the supplied boot.txt, depending on the monitor used.
Thanks for the write-up TaborFife. I repeated your steps and everything worked out fine. I did cross-compile u-boot and the trusted-firmware on another computer however. Currently the kernel version is:
$ uname -a
Linux RockPro64 5.3.13-1-ARCH #1 SMP Sun Nov 24 17:44:14 UTC 2019 aarch64 GNU/Linux
@TaborFife, have you managed to get this working using an eMMC module instead of a SD card? I tried it, but it doesn't boot:
U-Boot TPL 2020.01-rc5-00042-g6cb87cbb14 (Jan 02 2020 - 15:30:57)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
Channel 1: LP
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to
U-Boot SPL 2020.01-rc5-00042-g6cb87cbb14 (Jan 02 2020 - 15:30:57 +0100)
Trying to boot from MMC2
unable to select a mode
mmc_load_image_raw_sector: mmc block read error
Trying to boot from MMmmc_load_image_raw_sector: mmc block read error
Trying to boot mmc_load_image_raw_sector: mmc block read error
SPL: failed to rd ###
FATAL: read from port failed: Device not configured
(01-02-2020, 09:25 AM)Yoast Wrote: @TaborFife, have you managed to get this working using an eMMC module instead of a SD card? I tried it, but it doesn't boot:
Channel 1: LP
256B stride
Returning to
Hi, I'm able to boot from eMMC using the latest ROOTFS tarball. The latest kernel update seems to have nuked my setup though.
There is indeed a regression in linux kernel > 5.4.6
details here: https://gitlab.manjaro.org/manjaro-arm/p...4/issues/5
This impact both manjaro and arch linux.
If your system is impacted, there is a work around:
remove stmmac-platform.ko and rebuild it with this patch
diff -Naur linux-5.4-7/./drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c linux-5.4-6/./drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
--- linux-5.4-7/./drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c 2020-01-07 11:17:04.817218153 +0100
+++ linux-5.4-6/./drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c 2020-01-07 11:16:25.770550353 +0100
@@ -320,7 +320,7 @@
static int stmmac_dt_phy(struct plat_stmmacenet_data *plat,
struct device_node *np, struct device *dev)
- bool mdio = false;
+ bool mdio = true;
static const struct of_device_id need_mdio_ids[] = {
{ .compatible = "snps,dwc-qos-ethernet-4.10" },
They are urrently testing a fix and discussing it here:
https://lkml.org/lkml/2020/1/7/375
By the way, you have to know that there is an another issue an archlinux:
They think they are applying patches but then dont. They use git apply outside of a git repo : linux kernel is a .xz file and patches applied with git apply.
They just dropped my pull request: https://github.com/archlinuxarm/PKGBUILDs/pull/1749
I m currently using manjaro, so I didnt care about that.
Channel 1: LP
256B stride
Returning to
Good to know that it worked for you. Can you confirm the U-Boot version you are using? Is it also the 2020.01-rc5 version?
Channel 1: LP
256B stride
Returning to
I cloned the master at the time. Since it booted right away, I didn't really try a proper release.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 12 20,520 06-27-2026, 04:09 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 169,919 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,951 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,687 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 9,612 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,534 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 41,406 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 125,350 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 7,629 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,353 05-21-2023, 11:34 PM
Last Post: shpark
