i3blocks Manjaro battery status script
I did this to have battery-status on the i3bar:
#!/bin/bash #simple Shellscript for i3blocks on Pinebook pro #05012020 geri123@gmx.net Gerhard S. #battery-symbols: on Manjaro you need the awesome-terminal-fonts package installed! PERCENT=$(cat /sys/class/power_supply/cw2015-battery/capacity) STATUS=$(cat /sys/class/power_supply/cw2015-battery/status) case $((  $PERCENT >= 0 && $PERCENT <= 20 ? 1 :  $PERCENT > 20 && $PERCENT <= 40 ? 2 :  $PERCENT > 40 && $PERCENT <= 60 ? 3 :  $PERCENT > 60 && $PERCENT <= 80 ? 4 : 5)) in #        (1) echo $STATUS::"" ::$PERCENT%;;        (2) echo $STATUS::"" ::$PERCENT%;;        (3) echo $STATUS::"" ::$PERCENT%;;        (4) echo $STATUS::"" ::$PERCENT%;;        (5) echo $STATUS::"" ::$PERCENT%;; esac
and in the i3blocks-config:
[batterystat] command=sh ~/.config/i3blocks/scripts/batterystat interval=5
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,810 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 24,686 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 6,499 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 12,941 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,483 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 5,099 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 16,537 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 94,791 07-11-2020, 09:01 PM
Last Post: xmixahlx
  full disk encryption with luks on manjaro xfce limxr 48 111,752 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 13,590 06-23-2020, 12:41 AM
Last Post: pljanson
