default os: loop while login as rock
Hi there
I'm using a Pinebook Pro with default OS.
Problem: Suddenly I cannot login as user rock anymore. Giving the credentials it loops and shows the login mask again and again.
I created another user before (they worked well in parallel) which is still usable.
I used User rock for update purposes. And now I do not have the update button in the lower right side anymore.
Any idea how to fix the login or do I have to reinstall from scatch?
Any help / tip is very welcome. - Thanks
Regards Adrian
Hi Adrian,
Based on the problem you are describing, I suspect you may have changed the 'rock' user password.
If you added your new user to the sudo group, you can change the rock user password from your new user account by running the following within a terminal:
$ sudo passwd rock
If you did not add your new user to the sudo group, and you can run the following in a terminal to switch to the root user:
$ su root
And then enter the root user password (if you did not change it, the root password is 'root' without quotes). Then you can run the following within a terminal to change the rock password:
$ passwd rock
Regardless of how you restore the rock password, should you ever accidentally remove the update button, you can always run the following within a terminal to update the default Debian desktop shipped by the manufacturer:
$ sudo mrfixit_update.sh
(12-27-2019, 03:53 PM)hmuller Wrote: Hi Adrian,
$ sudo passwd rock
$ su root
$ passwd rock
Hello hmuller,
thanks for your detailed help.
Actually I followed your steps for solving this issue, but unfortunately resetting user's rock password to default passwd rock did not help.
It does still loop back to the login window. (After entering the credential the screen is black for 1-2 seconds and the login window appears again.) Confused
Anyway this is not that important since you mentioned :
So I can still update the system as my other user.
thanks again. All the best for 2020!
Regards, Adrian
< SNIP >
Regards, Adrian
It's a good idea to add sudo and include your user by group membership to sudoers. If for nothing else but these occasions.
If you want to then change a forgotten root user password, "sudo su -" gets you a root shell with environment, and then a regular "passwd" will change root, without asking for previous shadow entry.
This also helps when you are running things that sudo has difficulty with - such as some scripts. I hate editing these to prepend extra "sudo" commands to lines.
— Jeremiah Cornelius
@gritibaenz,
keymap issues drop to the bottom of the list of potential problems as the problem still occurs after resetting the password to "rock".
Now check the ownership of /home/rock/.Xauthority and /home/rock/.ICEauthority. From your second user account, open a console and login to the rock user: Ctrl-Alt-F1
Then run the following command to list the ownership of both files:
$ ls -l {.Xauthority,.ICEauthority}
The ownership of both files should look like this:
-rw------- 1 rock rock 66374 Dec 31 11:02 .ICEauthority -rw------- 1 rock rock   378 Dec 31 11:02 .Xauthority
If the owner/group does not show 'rock rock', then correct that using:
$ sudo chown rock:rock /home/rock/.Xauthority or $ sudo chown rock:rock /home/rock/.ICEauthority
Exit the console, return to your X11 session: Ctrl-Alt-F7
Logout of X11 and attempt to login as rock, let me know if any of the above was the culprit.
@hmuller
Thanks again - this way I could manage to login as rock again.
The Problem raises when following https://wiki.pine64.org/index.php/Pinebook_Pro :
You can change the default rock username and rock home directory by logging into root (credentials root/root) instead of the default 'rock' user and running the following in root terminal and substituting desired username for NewUser:
usermod -l NewUser rock usermod -d /home/rock -m NewUser
which I did for my newuser. But doing it that way, it seems that user rock and user NewUser are not independent.
because now I cannot login as NewUser anymore and the user:group for /home/NewUser/* is rock.rock .
What I wanted was, clone user rock and have an independent NewUser (based on user rock). - So I'll try to remove NewUser completely and create a NewUser with  the command useradd ...
Do you have suggestions how to do that?
(12-31-2019, 11:51 AM)Jeremiah Cornelius Wrote: < SNIP >
Regards, Adrian
Thanks for your hints.
Adrian
I am having almost this exact same issue with it seeming to be in a loop when trying to login as rock.  I have also created another user and have the same issue with this other user logon.  I can only login as root.  Did anyone solve this issue?
I have checked the ownership of /home/rock/.Xauthority and /home/rock/.ICEauthority as suggested above and it appears correct. But I am unable to login as rock.
I have another user (in addition to rock) created following https://phoenixnap.com/kb/create-a-sudo-user-on-debian
Bye Gritibaenz
  No Sound on Default Manjaro KDE carlosqueso 4 10,115 04-01-2021, 07:17 AM
Last Post: carlosqueso
  Graphical login hanging after password entry mhill8 2 6,785 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  PBP Went Blank After Login iscmob 2 7,675 12-07-2020, 09:28 AM
Last Post: iscmob
  Pinebook Pro Won't Accept Login GFreeman 16 31,290 09-03-2020, 11:44 AM
  Suspend with NVME not working - Default Debian appdev46 5 15,586 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  Login screen issue. LinuXchoicE 2 7,576 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Default OS update log Luke 194 454,715 06-11-2020, 11:25 PM
Last Post: xmixahlx
  OEM Script - Factory Default xmark 0 3,334 06-07-2020, 06:51 AM
Last Post: xmark
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 13,764 05-26-2020, 07:21 AM
Last Post: User 6582
  Stuck on login screen Kscott6969 0 3,599 04-20-2020, 10:58 PM
Last Post: Kscott6969
