Rockpro64 not stable... crashes now and then.
Ok. thank you. In your link they are lots of different images. Which one are you using ? So I will be able to test with exact same firmware.
I will start to test rockpro64-debian-mrfixit-190531.img (old version, but seems to be the last debian release of mrfixit). But the kernel doesnt match with yours:
Linux ab-rock.lan 4.4.180 #1 SMP Fri May 31 17:07:08 EDT 2019 aarch64 GNU/Linux
I started the hexdump test anyway
edit: the hexdump test was ok (but I did only one pass), but the syncthing test was not ok.
root@ab-rock:~# [ 1371.252433] ata1: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
[ 1371.253154] ata1: irq_stat 0x00000040, connection status changed
[ 1371.253683] ata1: SError: { CommWake DevExch }
[ 1371.254155] ata1: hard resetting link
[ 1381.254144] ata1: softreset failed (1st FIS failed)
[ 1381.254593] ata1: hard resetting link
[ 1383.255370] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1383.285388] ata1.00: HPA detected: current 2930275055, native 2930277168
[ 1383.285998] ata1.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
[ 1383.286601] ata1.00: 2930275055 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 1383.330393] ata1.00: configured for UDMA/133
[ 1383.330813] ata1: EH complete
[ 1383.331682] scsi 0:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
[ 1383.333163] sd 0:0:0:0: [sda] 2930275055 512-byte logical blocks: (1.50 TB/1.36 TiB)
[ 1383.333997] sd 0:0:0:0: [sda] Write Protect is off
[ 1383.334480] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1383.335120] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1383.423350] sda: sda1
[ 1383.424862] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1417.038227] EXT4-fs (sda1): recovery complete
[ 1417.062188] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
root@ab-rock:~#
root@ab-rock:~#
root@ab-rock:~# mv /home/abdel/.config/syncthing/ /home/rock/.config
root@ab-rock:~# chown -R rock:rock /home/rock/.config/syncthing/
root@ab-rock:~# [ 2100.880059] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8009cda130
[ 2100.880892] Internal error: : 96000210 [#1] SMP
[ 2100.881291] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[ 2100.882087] CPU: 2 PID: 345 Comm: scsi_eh_0 Not tainted 4.4.180 #1
[ 2100.882628] Hardware name: Pine64 RockPro64 (DT)
[ 2100.883035] task: ffffffc0f33eec00 task.stack: ffffffc0ed258000
[ 2100.883562] PC is at ahci_scr_read+0x70/0x98
[ 2100.883942] LR is at sata_scr_read+0x88/0x94
[ 2100.884317] pc : [<ffffff800863a328>] lr : [<ffffff800861f67c>] pstate: 80000145
[ 2100.884962] sp : ffffffc0ed25ba60
[ 2100.885254] x29: ffffffc0ed25ba60 x28: 0000000000000000
[ 2100.885726] x27: ffffffc0ed1d5e80 x26: 0000000000000001
[ 2100.886198] x25: ffffffc0ed1d6280 x24: ffffffc0ed1d4000
[ 2100.886670] x23: 0000000000000000 x22: ffffffc0ed25bb38
[ 2100.887141] x21: ffffffc0ed1d5e80 x20: ffffffc0ed25bb38
[ 2100.887613] x19: 0000000000000001 x18: 0000000000000001
[ 2100.888085] x17: 00e8000035c2bf53 x16: 0000000000adefff
[ 2100.888558] x15: ffffffbdc0000000 x14: 0000000000000000
[ 2100.889030] x13: 0000000000000000 x12: 0000000000000000
[ 2100.889502] x11: 0000000000000000 x10: 0000000000000000
[ 2100.889973] x9 : 0000000000000000 x8 : ffffffc0ed1d6280
[ 2100.890445] x7 : 0000000000000000 x6 : ffffffc0ed1d62f8
[ 2100.890917] x5 : 0000000000000000 x4 : ffffff800908f948
[ 2100.891388] x3 : 0000000000000130 x2 : ffffffc0ed25bb38
[ 2100.891860] x1 : 0000000000000030 x0 : ffffff8009cda130
[ 2100.892333]
[ 2100.892333] PC: 0xffffff800863a2a8:
[ 2100.892769] a2a8 52800013 9135c421 97fe26d4 17ffffe2 a9bd7bfd 910003fd a90153f3 f90013f5
[ 2100.893522] a2c8 aa0003f5 2a0103f3 aa1e03e0 aa0203f4 d503201f f94002a3 7100127f f95a3c60
[ 2100.894274] a2e8 b9402c63 f9401801 53196063 91040063 f9400820 54000268 54000061 b9401821
[ 2100.895025] a308 36e80201 b00052a4 9124a084 91008084 b8735881 34000161 8b21c063 8b030000
[ 2100.895778] a328 b9400000 d5033d9f b9000280 52800000 a94153f3 f94013f5 a8c37bfd d65f03c0
[ 2100.896531] a348 128002a0 17fffffb a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d503201f
[ 2100.897284] a368 f9400260 f9400000 f95a3c00 f9401800 b9400000 36400120 52801fe0 b903be60
[ 2100.898035] a388 90006dc2 d0006981 91363442 913f8421 aa1303e0 97ff9803 f9400bf3 a8c27bfd
[ 2100.898789]
[ 2100.898789] LR: 0xffffff800861f5fc:
[ 2100.899224] f5fc a90153f3 a9025bf5 aa0003f3 2a0103f5 aa1e03e0 aa0203f6 d503201f f9400274
[ 2100.899976] f61c d283d000 8b000280 eb00027f 54000180 f95a2280 eb00027f 54000120 aa1603e2
[ 2100.900727] f63c 2a1503e1 aa1303e0 94005758 a94153f3 a9425bf5 a8c37bfd d65f03c0 aa1303e0
[ 2100.901477] f65c 97fffb18 34000100 f9400680 aa1603e2 2a1503e1 f9406c03 aa1303e0 d63f0060
[ 2100.902230] f67c 17fffff3 12800bc0 17fffff1 a9ba7bfd 910003fd a90153f3 a9025bf5 a90363f7
[ 2100.902980] f69c a9046bf9 aa0103f5 aa0203f6 aa0003f7 aa1e03e0 d503201f d00085b3 b94012a0
[ 2100.903733] f6bc f940e274 a94066b8 97eb7eb5 8b000280 cb160001 910173a2 f100003f 52800001
[ 2100.904483] f6dc 9a80a2d6 aa1703e0 97ffffc4 2a0003f5 350003c0 b9405fb4 f940e27a 12000e94
[ 2100.905237]
[ 2100.905237] SP: 0xffffffc0ed25b9e0:
[ 2100.905672] b9e0 ed25bb38 ffffffc0 00000000 00000000 ed1d4000 ffffffc0 ed1d6280 ffffffc0
[ 2100.906425] ba00 00000001 00000000 ed1d5e80 ffffffc0 00000000 00000000 ed25ba60 ffffffc0
[ 2100.907178] ba20 0861f67c ffffff80 ed25ba60 ffffffc0 0863a328 ffffff80 80000145 00000000
[ 2100.907929] ba40 00000000 00000000 00000000 00000000 ffffffff ffffffff 00000000 00000000
[ 2100.908680] ba60 ed25ba90 ffffffc0 0861f67c ffffff80 ed1d5e80 ffffffc0 ed1d4000 ffffffc0
[ 2100.909432] ba80 00000001 00000000 00000000 00000001 ed25bac0 ffffffc0 0862c5a0 ffffff80
[ 2100.910182] baa0 ed1d6280 ffffffc0 ed1d5e80 ffffffc0 ed1d7940 ffffffc0 00003008 00000000
[ 2100.910934] bac0 ed25bb70 ffffffc0 0862cd60 ffffff80 ed1d4000 ffffffc0 ed1d5e80 ffffffc0
[ 2100.911686]
[ 2100.911686] X0: 0xffffff8009cda0b0:
[ 2100.912122] a0b0
[ 2100.962281] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8009cda0b0
[ 2107.963106] BUG: spinlock lockup suspected on CPU#2, scsi_eh_0/345
[ 2107.963651] lock: 0xffffff80096e0018, .magic: dead4ead, .owner: scsi_eh_0/345, .owner_cpu: 2
[ 2107.964398] CPU: 2 PID: 345 Comm: scsi_eh_0 Not tainted 4.4.180 #1
[ 2107.964938] Hardware name: Pine64 RockPro64 (DT)
[ 2107.965343] Call trace:
[ 2107.965571] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[ 2107.966047] [<ffffff80080883e8>] show_stack+0x24/0x30
[ 2107.966494] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[ 2107.966941] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[ 2107.967378] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[ 2107.967879] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[ 2107.968414] [<ffffff8008088428>] die+0x34/0x1b4
[ 2107.968814] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[ 2107.969304] [<ffffff8008093324>] do_sea+0x80/0x94
[ 2107.969718] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[ 2107.970176] Exception stack(0xffffffc0ed25b4c0 to 0xffffffc0ed25b5f0)
[ 2107.970742] b4c0: ffffffc0f33eec00 0000008000000000 ffffffc0ed25b690 ffffff8008422884
[ 2107.971425] b4e0: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[ 2107.972110] b500: ffffff80098f5148 0000000000000000 ffffffc0ed25b530 ffffff80080eda14
[ 2107.972795] b520: 0000000000000005 0000000000000000 ffffffc0ed25b5d0 ffffff80080edb74
[ 2107.973479] b540: ffffffc0ed25b650 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[ 2107.974164] b560: ffffffc0ed25b71c ffffff8009cda0b0 0000000000000004 00000040ee86b000
[ 2107.974849] b580: 0000000000000002 ffffffc0ed25b720 ffffffc0ed25b71c 00000000ffffffff
[ 2107.975533] b5a0: ffffff80099137ec 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[ 2107.976218] b5c0: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[ 2107.976901] b5e0: 0000000000adefff 00e8000035c2bf53
[ 2107.977329] [<ffffff80080825cc>] el1_da+0x24/0x84
[ 2107.977744] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[ 2107.978272] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[ 2107.978738] [<ffffff80080884ac>] die+0xb8/0x1b4
[ 2107.979139] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[ 2107.979627] [<ffffff8008093324>] do_sea+0x80/0x94
[ 2107.980040] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[ 2107.980499] Exception stack(0xffffffc0ed25b890 to 0xffffffc0ed25b9c0)
[ 2107.981061] b880: 0000000000000001 0000008000000000
[ 2107.981746] b8a0: ffffffc0ed25ba60 ffffff800863a328 ffffff800863a328 0000000080000145
[ 2107.982431] b8c0: 0000000000000025 ffffffc0ed1d6280 0000000000000001 ffffffc0ed1d5e80
[ 2107.983115] b8e0: ffffffc0f33eec00 ffffffc0ed25ba60 ffffff800861f67c ffffffc0ed25b930
[ 2107.983800] b900: ffffff80080825b8 0000000060000145 ffffff800976e0b8 0000000000000021
[ 2107.984484] b920: 0000008000000000 ffffff80098f55c0 ffffff8009cda130 0000000000000030
[ 2107.985169] b940: ffffffc0ed25bb38 0000000000000130 ffffff800908f948 0000000000000000
[ 2107.985853] b960: ffffffc0ed1d62f8 0000000000000000 ffffffc0ed1d6280 0000000000000000
[ 2107.986538] b980: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 2107.987222] b9a0: 0000000000000000 ffffffbdc0000000 0000000000adefff 00e8000035c2bf53
[ 2107.987906] [<ffffff80080825cc>] el1_da+0x24/0x84
[ 2107.988322] [<ffffff800861f67c>] sata_scr_read+0x88/0x94
[ 2107.988792] [<ffffff800862c5a0>] ata_eh_link_autopsy+0x4c/0x740
[ 2107.989310] [<ffffff800862cd60>] ata_eh_autopsy+0xcc/0xdc
[ 2107.989786] [<ffffff8008634ba0>] sata_pmp_error_handler+0x34/0x7bc
[ 2107.990328] [<ffffff8008639c90>] ahci_error_handler+0x48/0x78
[ 2107.990833] [<ffffff800862f194>] ata_scsi_port_error_handler+0xe0/0x578
[ 2107.991412] [<ffffff800862f6b0>] ata_scsi_error+0x84/0xa4
[ 2107.991890] [<ffffff8008608bcc>] scsi_error_handler+0x13c/0x430
[ 2107.992410] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[ 2107.992832] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[ 2136.177855] Watchdog detected hard LOCKUP on cpu 2
[ 2136.178281] ------------[ cut here ]------------
[ 2136.178708] WARNING: at kernel/watchdog.c:352
[ 2136.179090] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[ 2136.179879]
[ 2136.180020] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.180 #1
[ 2136.180545] Hardware name: Pine64 RockPro64 (DT)
[ 2136.180951] task: ffffffc0f3288d80 task.stack: ffffffc0f3298000
[ 2136.181476] PC is at watchdog_timer_fn+0x190/0x2e8
[ 2136.181898] LR is at watchdog_timer_fn+0x190/0x2e8
[ 2136.182320] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[ 2136.182964] sp : ffffffc0f7eebdf0
[ 2136.183256] x29: ffffffc0f7eebdf0 x28: 0000000000000002
[ 2136.183728] x27: ffffff80096d7720 x26: ffffff8009698260
[ 2136.184200] x25: ffffffc0f7eee278 x24: ffffffc0f329bda0
[ 2136.184672] x23: 0000000000000000 x22: 00000000000007c1
[ 2136.185143] x21: ffffff80096d6000 x20: ffffff80096982d8
[ 2136.185615] x19: ffffff8009698000 x18: 0000000000000005
[ 2136.186087] x17: 00e800003c33ff53 x16: 0000000000adefff
[ 2136.186558] x15: 0000000000000000 x14: 000000000000000a
[ 2136.187030] x13: ffffff80898f48e7 x12: 0000000000000030
[ 2136.187503] x11: 0000000000000006 x10: ffffff80098f48ef
[ 2136.187975] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[ 2136.188446] x7 : 6574636574656420 x6 : ffffff80098f491d
[ 2136.188918] x5 : 00000000fffffffe x4 : 0000000000000002
[ 2136.189390] x3 : 00000040ee856000 x2 : 00000040ee856000
[ 2136.189862] x1 : 0000000000000001 x0 : 0000000000000026
[ 2136.190335]
[ 2136.190335] PC: 0xffffff800812c6b8:
[ 2136.190771] c6b8 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 2136.191524] c6d8 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 2136.192276] c6f8 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[ 2136.193029] c718 91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[ 2136.193782] c738 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[ 2136.194534] c758 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 2136.195287] c778 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 2136.196037] c798 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[ 2136.196790]
[ 2136.196790] LR: 0xffffff800812c6b8:
[ 2136.197225] c6b8 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 2136.197976] c6d8 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 2136.198728] c6f8 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[ 2136.199480] c718 91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[ 2136.200232] c738 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[ 2136.200983] c758 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 2136.201734] c778 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 2136.202485] c798 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[ 2136.203238]
[ 2136.203238] SP: 0xffffffc0f7eebd70:
[ 2136.203673] bd70 000007c1 00000000 00000000 00000000 f329bda0 ffffffc0 f7eee278 ffffffc0
[ 2136.204422] bd90 09698260 ffffff80 096d7720 ffffff80 00000002 00000000 f7eebdf0 ffffffc0
[ 2136.205175] bdb0 0812c738 ffffff80 f7eebdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[ 2136.205928] bdd0 096d6710 ffffff80 0000020d 00000000 00000000 00000080 f2c00028 ffffffc0
[ 2136.206679] bdf0 f7eebe60 ffffffc0 08103104 ffffff80 f7eee278 ffffffc0 f7eedc00 ffffffc0
[ 2136.207432] be10 57283cb7 000001f1 f7eedc80 ffffffc0 09692000 ffffff80 00000001 00000000
[ 2136.208185] be30 098a07b8 ffffff80 57283cb7 000001f1 0812c5a8 ffffff80 f3288d80 ffffffc0
[ 2136.208938] be50 f7eee278 ffffffc0 096d6710 ffffff80 f7eebed0 ffffffc0 081036e8 ffffff80
[ 2136.209693]
[ 2136.209693] X6: 0xffffff80098f489d:
[ 2136.210128] 489c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.210880] 48bc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.211630] 48dc 00000000 00000001 00000000 30303020 32303330 33363130 34205d30 20636438
[ 2136.212381] 48fc 322e3633 39363930 58205d33 30203a36 66666678 38666666 38393030 39383466
[ 2136.213134] 491c 300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[ 2136.213885] 493c 33356662 70635f0a 32203a75 6463390a 30623061 6c6c690a 20656220 65736163
[ 2136.214637] 495c 6e657320 69746973 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[ 2136.215389] 497c 7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[ 2136.216140] 499c 2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[ 2136.216894]
[ 2136.216894] X10: 0xffffff80098f486f:
[ 2136.217337] 486c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.218089] 488c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.218840] 48ac 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.219592] 48cc 00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[ 2136.220343] 48ec 322e3633 34333033 34205d33 20636538 322e3633 39383631 58205d34 203a3031
[ 2136.221096] 490c 66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[ 2136.221846] 492c 74617473 36203a65 30303030 0a356331 33356662 70635f0a 32203a75 6463390a
[ 2136.222597] 494c 30623061 6c6c690a 20656220 65736163 6e657320 69746973 0a216576 73203b29
[ 2136.223349] 496c 65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[ 2136.224102]
[ 2136.224102] X13: 0xffffff80898f4867:
[ 2136.224545] 4864 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.225298] 4884 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.226049] 48a4 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.226803] 48c4 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.227559] 48e4 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.228310] 4904 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.229065] 4924 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.229817] 4944 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.230566] 4964 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.231322]
[ 2136.231322] X19: 0xffffff8009697f80:
[ 2136.231765] 7f80 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.232517] 7fa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.233269] 7fc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.234019] 7fe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.234774] 8000 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.235527] 8020 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.236281] 8040 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.237035] 8060 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.237788]
[ 2136.237788] X20: 0xffffff8009698258:
[ 2136.238230] 8258 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.238982] 8278 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.239739] 8298 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.240495] 82b8 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.241249] 82d8 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.242002] 82f8 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.242754] 8318 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.243509] 8338 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.244264]
[ 2136.244264] X21: 0xffffff80096d5f80:
[ 2136.244707] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.245459] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.246208] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.246958] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.247708] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.248460] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.249210] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.249961] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2136.250716]
[ 2136.250716] X24: 0xffffffc0f329bd20:
[ 2136.251159] bd20 00000000 00000000 f3288d80 ffffffc0 000001c0 00000000 08c6cdb0 ffffff80
[ 2136.251910] bd40 00000002 00000000 080913c4 ffffff80 f329bd60 ffffffc0 080914b8 ffffff80
[ 2136.252662] bd60 f329be70 ffffffc0 08c6d42c ffffff80 f329bdb0 ffffffc0 08cee258 ffffff80
[ 2136.253415] bd80 f24ffa10 ffffffc0 f24ff610 ffffffc0 f24ff800 ffffffc0 00000002 00000000
[ 2136.254168] bda0 f7ef2180 ffffffc0 ee856000 00000040 f7ef2180 ffffffc0 f329beb0 ffffffc0
[ 2136.254919] bdc0 ffffffff 00ffffff f5ed5e7f 0000000b 001d68fa 00000000 00000000 00000000
[ 2136.255672] bde0 f329bf50 ffffffc0 00000000 00000000 000009a0 00000000 0000011d 00000000
[ 2136.256423] be00 00000119 00000000 00000001 00000000 00000001 00000000 c0000000 ffffffbd
[ 2136.257173]
[ 2136.257173] X25: 0xffffffc0f7eee1f8:
[ 2136.257615] e1f8 ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7eee210 ffffffc0
[ 2136.258367] e218 f7eee210 ffffffc0 f7eee220 ffffffc0 f7eee220 ffffffc0 0812b194 ffffff80
[ 2136.259120] e238 f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[ 2136.259871] e258 00000001 00000000 00000216 00000000 00000215 00000000 f328d100 ffffffc0
[ 2136.260622] e278 f7eee278 ffffffc0 f7eee0e8 ffffffc0 00000000 00000000 57283940 000001f1
[ 2136.261375] e298 57283940 000001f1 0812c5a8 ffffff80 f7eedc80 ffffffc0 00000000 0000000b
[ 2136.262126] e2b8 0812c57c ffffff80 63746177 676f6468 0000312f 00000000 00000215 00000000
[ 2136.262879] e2d8 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 2136.263630]
[ 2136.263630] X26: 0xffffff80096981e0:
[ 2136.264073] 81e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.264825] 8200 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.265581] 8220 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.266336] 8240 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.267091] 8260 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.267844] 8280 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.268596] 82a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.269350] 82c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2136.270104]
[ 2136.270104] X27: 0xffffff80096d76a0:
[ 2136.270546] 76a0 00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0
[ 2136.271297] 76c0 00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000
[ 2136.272049] 76e0 00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0
[ 2136.272800] 7700 00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0
[ 2136.273551] 7720 ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[ 2136.274304] 7740 ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[ 2136.275057] 7760 00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[ 2136.275808] 7780 0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[ 2136.276559]
[ 2136.276559] X29: 0xffffffc0f7eebd70:
[ 2136.277002] bd70 000007c1 00000000 00000000 00000000 f329bda0 ffffffc0 f7eee278 ffffffc0
[ 2136.277753] bd90 09698260 ffffff80 096d7720 ffffff80 00000002 00000000 f7eebdf0 ffffffc0
[ 2136.278506] bdb0 0812c738 ffffff80 f7eebdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[ 2136.279259] bdd0 096d6710 ffffff80 0000020d 00000000 00000000 00000080 f2c00028 ffffffc0
[ 2136.280010] bdf0 f7eebe60 ffffffc0 08103104 ffffff80 f7eee278 ffffffc0 f7eedc00 ffffffc0
[ 2136.280763] be10 57283cb7 000001f1 f7eedc80 ffffffc0 09692000 ffffff80 00000001 00000000
[ 2136.281515] be30 098a07b8 ffffff80 57283cb7 000001f1 0812c5a8 ffffff80 f3288d80 ffffffc0
[ 2136.282266] be50 f7eee278 ffffffc0 096d6710 ffffff80 f7eebed0 ffffffc0 081036e8 ffffff80
[ 2136.283016]
[ 2136.283151] ---[ end trace dca43d00f74d00c6 ]---
[ 2136.283556] Call trace:
[ 2136.283776] Exception stack(0xffffffc0f7eebc10 to 0xffffffc0f7eebd40)
[ 2136.284340] bc00: ffffff8009698000 0000008000000000
[ 2136.285025] bc20: ffffffc0f7eebdf0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[ 2136.285710] bc40: 0000000000000026 0000000000000000 ffffffc0f7eebcf0 ffffff80080edb74
[ 2136.286394] bc60: ffffffc0f7eebd70 ffffff800937898b ffffff80096d6000 00000000000007c1
[ 2136.287079] bc80: 0000000000000000 ffffffc0f329bda0 ffffffc0f7eee278 ffffff8009698260
[ 2136.287762] bca0: ffffff80096d7720 0000000000000002 0000000000000004 ffffff8009692000
[ 2136.288447] bcc0: 0000000000000026 0000000000000001 00000040ee856000 00000040ee856000
[ 2136.289131] bce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[ 2136.289816] bd00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[ 2136.290501] bd20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[ 2136.291187] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[ 2136.291702] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[ 2136.292236] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[ 2136.292744] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[ 2136.293289] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[ 2136.293839] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[ 2136.294344] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[ 2136.294856] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[ 2136.295337] Exception stack(0xffffffc0f329bda0 to 0xffffffc0f329bed0)
[ 2136.295902] bda0: ffffffc0f7ef2180 00000040ee856000 ffffffc0f7ef2180 ffffffc0f329beb0
[ 2136.296586] bdc0: 00ffffffffffffff 0000000bf5ed5e7f 00000000001d68fa 0000000000000000
[ 2136.297271] bde0: ffffffc0f329bf50 0000000000000000 00000000000009a0 000000000000011d
[ 2136.297955] be00: 0000000000000119 0000000000000001 0000000000000001 ffffffbdc0000000
[ 2136.298640] be20: 0000000000adefff 00e800003c33ff53 0000000000000001 000001f15728394c
[ 2136.299324] be40: 0000000000000000 ffffffc0f1f10c00 0000000000000000 ffffff80098a0ce0
[ 2136.300009] be60: 0000000000000000 000001f1571908cd ffffff800983def0 0000000001193244
[ 2136.300693] be80: 0000000000000000 ffffffc0f329bed0 ffffff8008c43ccc ffffffc0f329bed0
[ 2136.301378] bea0: ffffff8008c43d00 0000000060000145 ffffffc0f329bed0 ffffff8008c43ccc
[ 2136.302060] bec0: ffffffffffffffff 0000000000000000
[ 2136.302488] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 2136.302920] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[ 2136.303446] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[ 2136.303914] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[ 2136.304373] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[ 2136.304887] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[ 2136.305435] [<0000000001193188>] 0x1193188
Message from syslogd@localhost at Dec 22 10:18:00 ...
kernel:[ 2] Internal error: : 96000210 [#1] SMP
kernel:[ 2107.963106] BUG: spinlock lockup suspected on CPU#2, scsi_eh_0/345
kernel:[ 2107.963651] lock: 0xffffff80096e0018, .magic: dead4ead, .owner: scsi_eh_0/345, .owner_cpu: 2
These "SError Interrupt" problems seem to be caused by the rockchip binary firmware. There is some discussion here: https://www.spinics.net/lists/arm-kernel/msg759563.html
It seems to use some memory that linux is unaware of. In that thread it says it's in the range 0x8400000-0x9600000. I tried reserving that range in the dtb, but that made me get a guaranteed "SError Interrupt" during boot. I tried reserving twice as much, and that seemed to fix it.
FWIW, here's the device tree node I used:
       reserved-memory {                #address-cells = <2>;                #size-cells = <2>;                ranges;                tee@0x8400000 {                        reg = <0x0 0x8400000 0x0 0x2400000>;                        no-map;                };        };
However, I'm not sure that's actually enough, nor if that's the only RAM the firmware needs to be reserved.
A better solution, which I'm now using, is to use the latest u-boot which can boot the rockpro64 without any blobs from rockchip. You need to have an arm-none-eabi-gcc and aarch64-linux-gnu-gcc compiler installed, then run the following commands:
git clone https://github.com/ARM-software/arm-trusted-firmware.git atf make -C atf CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31 git clone https://gitlab.denx.de/u-boot/u-boot.git u-boot cd u-boot/ git checkout v2020.01-rc5 make rockpro64-rk3399_defconfig BL31=../atf/build/rk3399/release/bl31/bl31.elf make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu-
Which gives you idbloader.img and u-boot.itb. Copy them to the rockpro64, and run the following: (Or put your SD card into your PC)
sudo dd if=idbloader.img of=/dev/mmcblk0 seek=64 sudo dd if=u-boot.itb of=/dev/mmcblk0 seek=16384 sync
Hopefully your rockpro64 still boots at this point. If so, the SError panics should be gone.
(01-04-2020, 08:37 PM)patstew Wrote: These "SError Interrupt" problems seem to be caused by the rockchip binary firmware
Seems to work. At least manjaro is working fine:
- no more oops with my hexdump test
- no more oops on PCIe driver.
Thank you
Am I having same problems?
https://forum.pine64.org/showthread.php?tid=9079
(02-08-2020, 09:55 AM)hemertje Wrote: Am I having same problems?
Try Armbian with modern kernel.
using:
Welcome to Armbian buster with Linux 4.4.210-rockchip64
this one
https://dl.armbian.com/rockpro64/archive...4.4.208.7z
Hi guys,
Is this issue still ongoing? Is there a uboot package that contains the aforementioned changes?
I'm also a bit confused if this is an issue only with OMV or it's common across all distros.
I've got the standard OMV4 NAS setup with rockpro64, 2gb ram, & the ASM1062 sata card sold by pine with 2 baracuda 2TB HDDS and I keep getting one of the hdds being dropped.
I had updated the kernel a few months ago to 5.6.0-1137-ayufan-ge57f05e7bf8 and it seems that the issue had gone away but the past few days one of the drives consistently fails when trying to reattach to the soft raid.
Also is the reason for this issue due to the driver for the ASM sata card trying to access the memory reserved by the rockchip binary?
Make sure you give it enough power. If you have a voltmeter you can verify this by checking the voltages on the board, like on GPIOs or USB port, etc.. You should have 5V not 4.8V for example. Same for 12V...
Just a thought. I don't have any experience with that board.
Other than first eliminating very well known power / SD card issues which eugenr already mentioned, I might suspect the SATA card.  I love Pine64 and I hate to have to say it, but I have heard more than one person having trouble with the card they sell in the store.  In my case, I just bought a different card, based on reports in this thread at Armbian wherein a few people report rock solid NAS usage for some years now.
I also (highly!) recommend Armbian, but OMV is based on it anyway, so...
Cheers,
TRS-80
Protocols, not Platforms
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,586 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 181,248 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,287 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,122 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,186 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,411 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 130,865 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,767 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,241 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,815 01-13-2023, 06:21 PM
Last Post: misterc
