Kodi on Android
#31
To Dietmar in german speek....
sag mal Dietmar warum ist KODI denn SOOOOOO Wichtig ?
Nur damit Du Videos abspielen kannst ?
Die Chinesen geben nun mal nicht gerne preis welche Hintertüren sie in
ihre ALL Winner CPU´s verbauen und daher haben die keinerlei Interesse daran
dies im OPEN Source Bereich kunt zu tun.
Die Leute von KODI wollen schon wissen was in dem CHIP ist .
Spätestens wenn an bestimmten Tagen diese Chips ein seltsames Eigenleben
entwickeln und weltweit die Router unbekannte Datenpakete gen China schicken
weis man das da MEHR drin ist.
Wenn dann die Kodi Software deswegen versagt bekommen sie die Prügel dafür.
Bei den Chips in den W-Lan Routern ist das ja schon passiert -das sie fleissig nach China
gesendet haben.
Der nächste C-Tag kommt bestimmt
#32
Look
https://m.youtube.com/watch?v=7Dxl9jeLyEw
#33
Echo??? anyone tried Kodi? any info?
#34
I have an install with it on a 64GB sandisk ultra card.  It is somewhat tolerable in current form.  The underlying android I was running it from was so unstable I didn't get a good reading.
I'm going to try a couple more microsd cards that are faster and see how many problems doing that solves.  The current version of android on a 2GB board has not done me well.
#35
(04-11-2016, 10:21 PM)yella-pine64 Wrote: I have an install with it on a 64GB sandisk ultra card.  It is somewhat tolerable in current form.  The underlying android I was running it from was so unstable I didn't get a good reading.
Thanks for the heads up. Im waiting on my P64 so once it comes i will also try faster SD card as well.
#36
(04-11-2016, 08:22 PM)Eddy120876 Wrote: Echo??? anyone tried Kodi? any info?
Working fine for me,.. installed using android, watching movie using video addons exodus, i using pine64 2 gb, 1080 smooth,.. connecting using ethernet,...
dani
#37
dani
@dend3 What is your set up like? Did you use the newest image and phoenixcard?
#38
Even though it's not for Android and hence not really relevant for you I guess: Yesterday I installed Kodi on longsleeps Ubuntu (2GB Pine). Even the mouse-cursor was too slow and moved only once every 5 seconds or so. Therefore it was of course completely unusable. I don't know why.
Just to let you know that other systems have problems with it as well.
#39
(04-14-2016, 01:16 AM)Keex Wrote: Even though it's not for Android and hence not really relevant for you I guess: Yesterday I installed Kodi on longsleeps Ubuntu (2GB Pine). Even the mouse-cursor was too slow and moved only once every 5 seconds or so. Therefore it was of course completely unusable. I don't know why.
Kodi has no Linux acceleration for allwinner SOCs, and also no plans to support it.
It should only work on Android.
Regards
#40
dani
yes,  using Android Image Release 20160216 burn using phoenixcard write mode startup,..
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,678 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 609,209 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,323 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,109 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,736 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,325 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,607 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,777 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 410,173 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,551 02-26-2019, 11:58 AM
Last Post: Twistedx
