Chromium Crashing if not Superuser
On my PBP, Chromium crashes every time I try to go to settings if I'm not running it as a superuser.  So I cannot enter my Google Passpharse to sync all my bookmarks.
It works fine if I run "sudo chromium-browser", but that seems to use a different profile.  The passphrase takes there, but when I go back on as a regular user, it's not synced.
I really don't want to run chromium as a super user every time.  Any thoughts on how to fix this?
Try a forum search, for chromium flags. I believe there are some flags passed at execution to run Chromium properly (at least in the default Debian.) You likely need to append those when launching it.
We'll have it solved in the next update to the default OS (1.8) due late December
(12-09-2019, 07:56 PM)Luke Wrote: We'll have it solved in the next update to the default OS (1.8) due late December
Thanks. It's exciting have a quirky little device and watch it grow.  I hope PBP really thrives. It's a nice little machine!
  I have two different versions of Chromium on my Pro! Nobot 2 5,633 06-01-2021, 02:34 PM
Last Post: Nobot
  Chromium Dino game is slow/glitchy stozi 0 3,221 04-21-2021, 08:18 AM
Last Post: stozi
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 30,746 03-12-2021, 10:46 AM
Last Post: spikerguy
  Issues with chromium-docker PVD 4 10,979 12-17-2020, 10:11 PM
Last Post: warehouses
  New PBP crashing every 5 min Lane23 2 5,069 11-07-2020, 10:19 PM
  KDE crashing bastafari 2 6,304 10-01-2020, 10:48 AM
Last Post: bastafari
  How to flash the emmc when it has Chromium on it? U47 3 7,847 07-10-2020, 10:07 AM
Last Post: U47
  Chromium browser on PBP can't upload files on websites Wawe 0 3,464 07-03-2020, 11:06 AM
Last Post: Wawe
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 13,800 05-26-2020, 07:21 AM
Last Post: User 6582
  Chromium will not start sititahwsi@gmail.com 5 10,621 03-06-2020, 05:17 AM
Last Post: jiyong
