Can't reinstall debian after breaking pre-installed OS
You can just download the latest mrfixit image and dd it to the emmc while booted from sdcard, that will work.
(11-27-2019, 08:39 PM)crownest Wrote: Are there any specific instructions on flashing the eMMC module?  Do you just flash the image using dd or will that cause issues?
I wrote a method to copy a working OS around, allowing repartitioning and adding physical swap partition. It preserves the U-Boot & bootability, in a clumsy way, but it worked for me multiple times.
Here is a link;
https://forum.pine64.org/showthread.php?tid=8419
It does require all command line work and assumes some familiarity with Linux command line tools. So it's not for everyone.
Arwen Evenstar
Princess of Rivendale
I flashed the latest mrfixit built and used dd to write to the eMMC, but not my PBP will not boot. I suspect I screwed something up along the way and overwrote the bootloader. How can I rebuild from scratch back to a usable machine?
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,732 06-26-2025, 09:20 PM
Last Post: reukiodo
  Official Debian support moonwalkers 64 122,582 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 12,379 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 12,297 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 23,286 09-07-2023, 09:38 PM
  With the help of a friend, I installed a beautiful deep os distribution, but I won't wangyukunshan 0 1,990 03-03-2023, 10:56 PM
Last Post: wangyukunshan
  org.kde.plasma.core not installed (Manjaro) twirlip 0 2,497 01-06-2023, 09:47 AM
Last Post: twirlip
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,870 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 5,902 12-09-2022, 05:04 AM
Last Post: ndp
  PineBook HOW TO REINSTALL ARCH-Manjaro. Ice-O-Star 0 2,657 10-22-2022, 10:46 AM
Last Post: Ice-O-Star
