Reboot problem on latest ayufan and 4.4
Reboot problem mentioned "Fixed" in 0.7.11 ( https://forum.pine64.org/showthread.php?tid=6706&highlight=0.7.11+reboot ) seems back again.
100% repeatable "sudo reboot" leads to hang on next kernel boot on both 0.7.11 and 0.7.12 pre-release.
System hangs after
[    0.002074] Console: colour dummy device 80x25 [    0.002493] console [tty0] enabled [    0.002815] bootconsole [uart0] disabled
lines right before
[    0.003210] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
line that appears next after cold boot.
mrfixit2001 kernel reboots fine as well as ayufan mainline (though the latter misses eMMC which is a showstopper).
Attaching a long log file containing normal boot and a hang after restart.
Strangely... another board (same RockPRO64 v2.1 4g) manufactured 1 month earlier doesn't have the issue. I tried swapping eMMC to make sure it's not a tainted distributive and the problem remained on the same board each time.
Any ideas?
.log   RockPRO64_reboot_hang.log (Size: 80.55 KB / Downloads: 588)
(03-02-2019, 04:37 PM)/dev/null Wrote: Reboot problem mentioned "Fixed" in 0.7.11 ( https://forum.pine64.org/showthread.php?tid=6706&highlight=0.7.11+reboot ) seems back again.
System hangs after
lines right before
Any ideas?
After updating the latest kernel, there is the same problem to me...
kernel-5.3.0 : The system is holding for 20 ~ 30 seconds and booting is fine
kernel-4.4.193-rockchip-dev : The system is holding for 20 ~ 30 seconds. reboot...
kernel-4.4.167-1213-rockchip-ayufan-g34ae07687fce : delay 1 second, booting is fine
[ 0.003716] printk: console [tty0] enabled
[ 0.004114] printk: bootconsole [uart8250] disabled
-->> no response..
or reboot
Why does it happen?
1: kernel-5.3.0-rc4-dev
2: kernel-5.3.0-rc4-dev-memtest
3: kernel-4.4.193-rockchip-dev
4: kernel-4.4.193-rockchip-dev-memtest
5: kernel-4.4.167-1213-rockchip-ayufan-g34ae07687fce
6: kernel-4.4.167-1213-rockchip-ayufan-g34ae07687fce-memtest
Would you help me?
/etc/lsb-releaseBig GrinISTRIB_ID=Ubuntu
/etc/lsb-releaseBig GrinISTRIB_RELEASE=18.04
/etc/lsb-releaseBig GrinISTRIB_CODENAME=bionic
/etc/lsb-releaseBig GrinISTRIB_DESCRIPTION="Ubuntu 18.04.3 LTS"
/etc/os-release:NAME="Ubuntu"
/etc/os-release:VERSION="18.04.3 LTS (Bionic Beaver)"
/etc/os-release:ID=ubuntu
/etc/os-release:ID_LIKE=debian
/etc/os-releaseTongueRETTY_NAME="Ubuntu 18.04.3 LTS"
/etc/os-release:VERSION_ID="18.04"
/etc/os-release:HOME_URL="https://www.ubuntu.com/"
/etc/os-release:SUPPORT_URL="https://help.ubuntu.com/"
/etc/os-release:BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
/etc/os-releaseTongueRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
/etc/os-release:VERSION_CODENAME=bionic
/etc/os-release:UBUNTU_CODENAME=bionic
Regards,
Nick.
Hi Nick, welcome to the forums. You have managed to dig up an old thread but no matter :-)
I have no problems rebooting with
$ uname -a Linux rpro64.dukla.net 4.4.197-1236-rockchip-ayufan-g30faab37e339 #1 SMP Tue Oct 22 11:35:10 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux $ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 19.10 Release: 19.10 Codename: eoan
I couldn't get 5.3.0-rc4 to boot at all.
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,562 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,937 04-23-2023, 01:32 PM
Last Post: diederik
Sad Problem with DD Re1L 2 4,296 07-24-2022, 04:27 AM
Last Post: CounterPillow
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,419 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  ayufan kernel update unbootable TheHunter 2 6,125 03-12-2021, 05:17 PM
Last Post: LMM
Question Ayufan RockPro64 updates? hemertje 3 10,339 10-22-2020, 01:16 PM
Last Post: dukla2000
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 9,935 10-22-2020, 01:12 PM
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 6,276 04-17-2020, 02:53 AM
Last Post: Thra11
  New Pre-release 0.10.9 from Ayufan Bullet64 0 3,932 04-09-2020, 06:49 AM
Last Post: Bullet64
  Problem with compiling ayufans linux kernel voegelit 4 10,832 01-14-2020, 07:38 AM
Last Post: patstew
