Install OS directly to eMMC?
It seems all the OS install tutorials make use of a SD card. Given that the phone doesn't come with a SD card, it is possible to install an OS directly to the eMMC?
Theoretically yes, the A64 SoC used in the PinePhone has a special bootloader mode called FEL mode, which gives you a special device on the USB port, which in turn allows you to upload code and run it. This can be used to upload a loader that exposes the eMMC as USB mass storage. But I am not sure if that is easier than just using a sdcard to write an image to the eMMC.
I am sure it does come with an sd card slot,
One of the things you CAN DO with the Pine Phone is test OS'es from an sd card.
I do not know if the eMMC is removable, but I hope it is.
*  We Sure could use a wiki for the Pine Phone  !
Update: Jan. 09, 2020
SO, the Brave Heart does have a soldered in 16gb eMMC
After installing a OS we may wish to use the SD card for added storage.
There is the start of a Wiki, though it hopefully will be growing as time goes.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(11-21-2019, 02:31 PM)bcnaz Wrote: I am sure it does come with an sd card slot,
I don't believe it is. This got brought up yesterday in the subreddit. From https://ameridroid.com/blogs/ameriblogs/...rom-tl-lim
Quote:The eMMC on the PinePhone is surface-mounted and not socketed
IIRC, the decision was made to allow more room internally, for other needed boards.
Also, I noticed the other day that some users have already begun gathering information and have started a few wiki pages for the phone.
Yeah but I prefer to bypass the SD card slot since the eMMC will probably have better performance.
(11-21-2019, 02:27 PM)xalius Wrote: Theoretically yes, the A64 SoC used in the PinePhone has a special bootloader mode called FEL mode, which gives you a special device on the USB port, which in turn allows you to upload code and run it. This can be used to upload a loader that exposes the eMMC as USB mass storage. But I am not sure if that is easier than just using a sdcard to write an image to the eMMC.
Ah, it looks to be possible on the Pine A64 and the Pinebook:
https://wiki.pine64.org/index.php/NOOB#F...es_Only.29
Is there a FEL button on the pinephone? Also, I'm curious why the Pine A64 needs a SD card with "FEL code" when the Pinebook doesn't need that.
.1) I figured to try a few different OS'es before installing one
.2) When I went to the wiki a few minutes ago and hit search for 'Pine phone'
It did not yield any results, but suggested I start a page.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(11-21-2019, 02:17 PM)tahayassen Wrote: It seems all the OS install tutorials make use of a SD card. Given that the phone doesn't come with a SD card, it is possible to install an OS directly to the eMMC?
Yes, you can use FEL mode, but I haven't tried it because I haven't played with it before.
But personally, I could boot to a Linux session on the phone and dd the image to the internal eMMC.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
(11-21-2019, 03:29 PM)bcnaz Wrote: .1)  I figured to try a few different OS'es before installing one
Try hardware page here and software page here.
YEP,   those links go to the pine phone,
Yesterday I went the wiki from the icon at the top of the forum page,  and found no listing for the pine phone..
THANK YOU  !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
i could transfer PostmarketOS Image from the sdcard to the emmc with dd.
I used this command from the PinePhone Terminal (Or better ssh)
dd if=/dev/mmcblk0 of=/dev/mmcblk2 bs=1M
It will take about 15min (depending on the speed of your card), in the end it will show en error about not enough space - just ignore it.
Working fine
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,388 11-17-2025, 07:49 AM
Last Post: danm1988
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 81,224 07-26-2024, 10:35 PM
Last Post: Peter Gamma
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 9,989 04-09-2023, 06:08 PM
Last Post: zetabeta
  Install OS Permanently ismkdc 1 3,593 03-20-2023, 01:13 PM
Last Post: fxc
Question PinephonePro can't Flashing to the eMMC ricardo 0 2,134 08-21-2022, 05:51 AM
Last Post: ricardo
  install packages pamac anbox neithan76 0 2,059 07-18-2022, 07:13 AM
Last Post: neithan76
  How to replace the home folder on eMMC ragreenburg 2 4,562 03-31-2022, 02:19 PM
Last Post: ragreenburg
  Wipe out eMMC before flashing new OS? zkajdan 15 22,912 11-13-2021, 03:10 AM
Last Post: zetabeta
  Streamlined jmms install amindfv 1 3,667 10-29-2021, 07:04 AM
Last Post: TRS-80
  Anbox: install Google Services sonic 0 3,332 02-07-2021, 04:45 AM
Last Post: sonic
