Rock64 lost connection after high I/O traffic
Hello Everybody, I´m new here and ask for help in this matter.
I have a Rock64 4G v2 and a tried it with many different Ubuntu bionic and Debian os, as:
-   Armbian_5.69_Rock64_Ubuntu_bionic_default_4.4.167
-   Armbian_5.90_Rock64_Ubuntu_bionic_default_4.4.182
-   Armbian_5.98_Rock64_Ubuntu_bionic_default_4.4.192
-   Armbian_5.98_Rock64_Debian_buster_default_4.4.192 (last one).
With all those os I get the same errors after dmesg: pls compare https://pastebin.com/0bxG6RC1
Do you think it is an hardware (memory) problem?
After normal boot and a while it get stuck and lost ssh or Ethernet connections.
I really don´t know what can I do with this SBC. Could yoo please help me?
How are you booting your system. Possibly a bad SD card. Also check out your power supply. Possibly under powered on boot. Also try changing your HDMI cable.
(11-12-2019, 03:39 PM)Rocklobster Wrote: How are you booting your system. Possibly a bad SD card. Also check out your power supply. Possibly under powered on boot. Also try changing your HDMI cable.
Thank you for reply. The System boots on a NEW flashed 16GB microSD card (SanDisk, A1 class). Before I had a corrupted 32GB microSD card of Samsung Pro Endurance. The power supply is still the EU Original one I've purchased from the Dealer in Germany. I've never used the Rock64 with Monitor and HMDI cable, but only on ssh Terminal.
Try connecting a HDMI monitor to the board and examine the boot screen.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,140 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,706 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 95,912 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,988 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,387 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,378 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,913 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,089 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,978 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,490 09-01-2024, 06:05 AM
Last Post: RaymondDay
