thunderbird crashes on startup on default Debian Mate platform
(11-11-2019, 03:00 PM)Der Geist der Maschine Wrote: thunderbird from Debian 8 works (at least is starts - I have not actually used it).
If you want to install it manually:
$ wget http://security.debian.org/debian-security/pool/updates/main/t/thunderbird/thunderbird_60.9.0-1~deb8u1_armhf.deb # dpkg -i thunderbird_60.9.0-1~deb8u1_armhf.deb
Debian 8 is supported till June 30 2020. If you want to track security updates for thunderbird, you have to figure out how to add exactly this deb package to your /etc/apt/sources.list file.
Yep, that works for me  Smile
Installed as per wget command above, and it works just fine. I've locked the installed version until I figure out the correct entry in sources.list for tracking Debian 8 updates.
Thank you for the info
(11-11-2019, 03:30 PM)bcnaz Wrote: *
Perhaps try Evolution (?)  that also ships in the original Debian....
Tried Evolution and it works as does geary , but I prefer to stick with thunderbird as I use it across most of my devices.
I think I'll switch to Evolution for now. Partly also because I'll need some of evolution's back end to add my CalDav calendar accounts anyway. I was trying Claws Mail, but its insistence on creating IMAP folders for "Queue" is annoying. I hope Thunderbird gets fixed in the future. I too prefer using it on devices where it can be used.
Ben
(11-11-2019, 12:55 PM)embhorn Wrote: I also had this issue with the stock Debian/Mate. I installed the Ubuntu/Mate image and now Thunderbird works.
What version of Ubuntu/Mate Thunderbird did you load and where did you find it?
Pretty sure I just did
apt install thunderbird
Its an older version, but precompiled for ARMH. I've moved back to the default OS, so no more thunderbird.
Had the same issue with stock Debian, though in trying it on an SD card created with Debian installer script worked, odd but I am still distro hopping, so just reporting my findings.
  Use SD to install new OS over pinebook debian Rudy558 10 30,386 03-09-2025, 11:17 AM
Last Post: davisthomas
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 500,783 05-12-2023, 06:09 AM
Last Post: korreckj328
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 2,637 10-08-2022, 11:03 AM
Last Post: omarcomputing
  Main Stream Debian on Pinebook Pro ? bcnaz 4 7,528 08-22-2021, 09:11 AM
  No Sound on Default Manjaro KDE carlosqueso 4 10,104 04-01-2021, 07:17 AM
Last Post: carlosqueso
  Audio with Debian GloriousCoffee 5 13,122 10-15-2020, 01:22 PM
Last Post: Mangled
  help on setting up debian (or ubuntu) on micro sd card pine76 2 12,140 09-17-2020, 05:10 PM
Last Post: bcnaz
  Suspend with NVME not working - Default Debian appdev46 5 15,542 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
  Default OS update log Luke 194 453,422 06-11-2020, 11:25 PM
Last Post: xmixahlx
  OEM Script - Factory Default xmark 0 3,324 06-07-2020, 06:51 AM
Last Post: xmark
