Pinebook serial console usage
Is the Pinebook Serial Console usable with the Pinebook Pro?
On mine PBP, when I used the Pinebook serial console, it seems to lead to eMMC not responding: when plugged-in from cold boot, I got DDR initialization then it hangs; if I plug the jack after DDR initialization, I got eMMC timeout.
Here is a sample serial output, from a cold boot:
DDR Version 1.20 20190314 In channel 0 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 400MHz 0,1 channel 0 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 800MHz 1,0 Channel 0: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,800MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD OUT DDR Version 1.20 20190314 In soft reset SRX
Then it hangs indefinitely. The power LED stays off.
When attaching the jack after u-boot load from eMMC:
1:      PINEBOOKPRO 2:      PINEBOOKPRO-prev-kernel Enter choice: 1 1:      PINEBOOKPRO Retrieving file: /Image ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** Skipping PINEBOOKPRO for failure retrieving kernel 2:      PINEBOOKPRO-prev-kernel Retrieving file: /Image.bak ** Unable to read file /Image.bak ** Skipping PINEBOOKPRO-prev-kernel for failure retrieving kernel SCRIPT FAILED: continuing... ** fs_devread read error - block Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc fail to send stop cmd rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc fail to send stop cmd mmc_bread: Re-init mmc_read_blocks error rkparm_init_param_from_storage param read fail RKPARM: Invalid parameter part table mmc fail to send stop cmd ...
With the jack plugged-in but the USB plug not attached to a computer, it boots normally.
What am I doing wrong?
(11-08-2019, 10:25 AM)nemunaire Wrote: With the jack plugged-in but the USB plug not attached to a computer, it boots normally.
Perhaps nothing?  There are problems reported with using the Pine64 cable with the PBP.
https://forum.pine64.org/showthread.php?tid=7746&page=2
According to this page, https://nixos.wiki/wiki/NixOS_on_ARM/PIN...al_console :
"It is not recommended to connect the serial adapter to pin 10 (RX) while booting, as this often causes the board to hang early in the bootloader."
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,969 10-05-2026, 12:42 PM
  Replacement battery for PineBook Pro DrYak 5 9,671 02-28-2026, 09:17 PM
  pinebook pro dixplays vertical stripes WEF 2 5,259 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 5,859 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 5,034 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 5,102 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 4,057 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 240,540 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 15,753 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 14,297 12-27-2022, 03:31 PM
Last Post: samtux
